Accuphase C-200 Pre & P-300 Power amplifier pair (sold)
Accuphase vintage C-200 Pre amplifier and P-300 Power amplifier pair.
This is the famous first matching pre/power pair produced by Accuphase
All buttons & switches are functioning and power VU meters are working with beautiful warm light.
Both units are in original condition. Good physical condition as per photo.
4 pcs of Spade fork for Banana plug will be provided for speaker terminals to accept common banana jacks.
Both units are local voltage (240VAC)
Made in Japan.
Selling for RM6900 (SOLD)
Contact Peter 012-3820333
C-200
Total harmonic distortion: 0.05%
Input sensitivity: 2mV (MM), 200mV (line)
Signal to noise ratio: 73dB (MM), 90dB (line)
Output: 10V (Pre out Max)
Dimensions: 445 x 152 x 355mm
Weight: 14kg
P-300
Power output: 150 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.1%
Damping factor: 60
Input sensitivity: 1V
Signal to noise ratio: 100dB
Semiconductors: 73 x transistors, 1 x IC, 2 x thermistors
Weight: 25kg
Made in Japan.
C-200
Weight: 14kg
P-300
Damping factor: 60
Weight: 25kg
Last edited by peterclting on Sun Nov 12, 2023 4:49 pm; edited 7 times in total (Reason for editing : SOLD)
- Number of posts : 2213
» Accuphase Pre C200 & Power P300 Amplifier Pair (sold)
» Accuphase A50 power amplifier SOLD
» Accuphase P-250 power amplifier SOLD
» Accuphase A30 Class A Power Amplifier ( SOLD )
» Accuphase P-102 Class A Power Amplifier (Used) SOLD
