Furutech HF-X NCF HDMI I2S 1.2m cable
2 posters
Furutech HF-X NCF HDMI I2S 1.2m cable Empty Furutech HF-X NCF HDMI I2S 1.2m cable
Post by loonar92 Wed Sep 27, 2023 10:09 am
FEATURES
NCF Connector Shell (Multi-material Hybrid Construction Incorporates Furutech’s top anti-static resonance damping NCF material – eliminating electrical/mechanical vibration and static derived noise, increasing picture and sound resolution, boosting color vividness, and delivering blacker backgrounds. NCF features a special crystalline material that has two 'active' properties. First, it generates negative ions that eliminate static. Second, it converts thermal energy into far infrared. Furutech combines this remarkable material with nano-sized ceramic particles and carbon powder for their additional 'piezoelectric effect' damping properties. The resulting Nano Crystal² Formula is the ultimate electrical and mechanical damping material. Created by Furutech, it is found exclusively in Furutech products.
  • Supported Bandwidth: Superior 48Gbps (GB/sec) bandwidth delivering ULTRA HIGH SPEED HDMI™ CABLE 8K/60p
  • Supported signal specifications: 8K/60p/48Gbps , 4K/120p/32.08Gbps , HDCP1.4/2.2/2.3, eARC/ARC, HDR10/HDR10+ , VRR/60Hz~240Hz(Refresh rate) , DSC, QMS, QFT, ALLM.
  • Thick gold-plated contacts: HDMI A connector parts treated with Furutech’s α(Alpha)-Process (2-Step Alpha Cryogenic and Demagnetizing Process) to deliver stable, optimized signal transmission. Thick layer of gold plating on contacts offer reliable and stable transmission with extreme performance.
  • Double Layer Aluminum Foil Shields prevent Static and EMI: Exceeding stipulated specifications for Crosstalk and Noise, the HDMI-HF-X-NCF features double aluminum foil shielding for each twisted conductor.
  • Main conductor: α (Alpha) conductor (26AWG Silver-platedμ-OFC) for improved conductivity and stable transmission for extreme quality sound and picture reproduction.
  • Antiresonance Sheath: passing UL/CL3 flame resistance testing and RoHS compliant, the very flexible PVC used in the HDMI-HF-X-NCF will reduce effects of electrical and mechanical resonance on signal transmission.
  • To ensure stable ULTRA HIGH SPEED HDMI™ CABLE 8K/60p/48Gbps transmission, the HDMI-HF-X-NCF cable has purposely been constructed to have a rigid build.
Item Condition: 9/10
Price: RM 750
Original Furutech HDMI cable bought from local dealer.
Comes with original box.
Furutech HF-X NCF HDMI I2S 1.2m cable Dsc_0712
Furutech HF-X NCF HDMI I2S 1.2m cable Dsc_0711
Furutech HF-X NCF HDMI I2S 1.2m cable Dsc_0710
loonar92
Regular
Regular
Number of posts : 50
Registration date : 2015-02-10
Furutech HF-X NCF HDMI I2S 1.2m cable Empty Re: Furutech HF-X NCF HDMI I2S 1.2m cable
Post by loonar92 Mon Oct 09, 2023 11:05 pm
loonar92
Regular
Regular
Post by loonar92 Thu Nov 02, 2023 11:40 pm
loonar92
Regular
Regular
Post by loonar92 Thu Nov 30, 2023 9:09 am
loonar92
Regular
Regular
Post by arremie Thu Nov 30, 2023 12:48 pm
Contact number?
arremie
arremie
Number of posts : 533
Registration date : 2009-02-09
Source(s): Oppo
Amplification: Parasound
Speakers: Klipsch
