Gato Audio PM-2 Stand-mounted Speakers
Gato Audio PM-2 Stand-mounted Speakers Empty Gato Audio PM-2 Stand-mounted Speakers
Post by raymond88 Fri Nov 10, 2023 3:03 pm
Item: Gato Audio PM-2 Stand-mounted Speakers
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with original boxs.
New was RM7500.
Price: RM3500 RM3200 or swap/topup
Gato Audio PM-2 Stand-mounted Speakers Gato111
Gato Audio PM-2 Stand-mounted Speakers Gato211
Gato Audio PM-2
Look at these curves!
The elegant curve of the housing is more than just a design effect. The specific geometry of the enclosure eliminates internal standing waves because reflections between walls are never synchronized. The cabinet geometry has been carefully calculated so that any vibrations from the front baffle are immediately transferred to the rear baffle, where they are harmlessly absorbed by the rounded rear profile integrated into the cabinet, specifically to provide additional mass loading to help dampen resonance and vibration.
Powerful engines
The PM-2 uses exclusive versions of Gato Audio's legendary Danish 38mm Ring Radiator tweeter and woofer/midrange driver. This highly praised driver design is used in some of the world's most expensive High End loudspeakers and is widely recognized for its accuracy, detail reproduction and performance.
The most important features:
2-way system
Bass-reflex design
Magnetically attached speaker covers
Designed, developed and built in Copenhagen, Denmark
SPECIFICATION
TRANSFERBAND: 50Hz - 25kHz (-6dB)/td>
SENSITIVITY:
89dB
RECOMMENDED AMPLIFIER POWER: 50 to 300 watts
NOMINAL IMPEDANCE: 4 ohms
CONNECTORS: Gold-plated 4mm terminals/plugs, bi-wire
HIGH FREQUENCY: 38 mm ring speaker, powerful ferrite motor and optimized chamber
MEDIUM AND LOW FREQUENCY: 170mm paper cone. low-loss suspension, motor with short-circuit rings and optimized voice coil
WIDTH x HEIGHT x DEPTH: 200 x 390 x 370 mm / 7.9 x 15.4 x 14.6 in
WEIGHT: 14 kg / 31 lbs
Gato Audio PM-2 Stand-mounted Speakers Gato511
Gato Audio PM-2 Stand-mounted Speakers Gato311
Gato Audio PM-2 Stand-mounted Speakers Gato411
Gato Audio PM-2 Stand-mounted Speakers Gato611
Gato Audio PM-2 Stand-mounted Speakers Gato710
Number of posts : 9647
Gato Audio PM-2 Stand-mounted Speakers Empty Re: Gato Audio PM-2 Stand-mounted Speakers
Post by raymond88 Fri Nov 17, 2023 9:57 pm
Post by raymond88 Fri Nov 24, 2023 9:45 am
