Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm
Item: Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm
Condition:10/10. Item is NOS (New Old Stock). Item is BRAND NEW IN BOX.
Ultra rare and very few manufactured.
Retail Price was £5000
Price:RM11.5k RM9.9k or swap/topup
![Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm Musica26](https://i.servimg.com/u/f88/14/76/78/48/musica26.jpg)
Excerpt from ZStereo talking about the M1 Turntable:
"Each chassis plate was of a different mass, thereby putting their natural resonance points are at different frequencies. The double pole isolation system between both chassis plates is both vertically and horizontally compliant thanks to rubber suspension, and also has a very low natural resonant frequency..."
"The inverted bearing ran milspec high carbon steel ground to better than 5 micron tolerance, with a 0.1 micron surface finish. At the top of the shaft was a high quality ball bearing in milspec high carbon steel, machined to a spherical accuracy of better than 2 microns. The surface finish was claimed to be better than 0.1 microns. The outer shell was made from high tensile stainless steel with a milspec brass insert which has a tightly toleranced lubrication spiral. The contact point between the outside shell and bearing was a closely toleranced PTFE pad.
An impulseless DC motor (what MF called, “the most expensive brushless motor available”) was used, with accuracy controlled by an optical sensor mounted on the motor which continually monitored shaft speed. This was fed into a 16-bit microprocessor running a ‘fuzzy logic’ algorithm to control the DC drive voltage. MF claimed speed accuracy within 0.2%. Unusually, a rotary pitch control was fitted giving a semitone (i.e. 6%) of adjustment, with a centre detente to indicate precise speed. As was common practice by then, the power supply is in a separately shielded box, along with the electronics which drive the motor."
![Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm Musica27](https://i.servimg.com/u/f88/14/76/78/48/musica27.jpg)
![Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm Musica25](https://i.servimg.com/u/f88/14/76/78/48/musica25.jpg)
![Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm Musica28](https://i.servimg.com/u/f88/14/76/78/48/musica28.jpg)
![Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm Musica29](https://i.servimg.com/u/f88/14/76/78/48/musica29.jpg)
![Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm Musica31](https://i.servimg.com/u/f88/14/76/78/48/musica31.jpg)
![Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm Musica32](https://i.servimg.com/u/f88/14/76/78/48/musica32.jpg)
https://www.audiogon.com/listings/lisb16f5-vpi-super-prime-scout-belt-driven-turntable-record-player-w-jmw-10-tonearm-ortofon-2-turntables
https://www.usaudiomart.com/details/649679158-musical-fidelity-m1-turntable-with-sme-m2-9-tonearm/
https://www.canuckaudiomart.com/details/649657889-musical-fidelity-m1-turntable/
https://www.usaudiomart.com/details/649123313-musical_fidelity_m1_turntable_class_a_component/
https://www.analogplanet.com/content/analog-corner-104
https://www.musicalfidelity.com/uploads/manuals/English/m1_eng.pdf
https://zstereo.co.uk/2015/06/01/musical-fidelity-m1/
Price:
» Musical Fidelity M1 Turntable w/ SME M2-9 Tonearm
» Garrard 401 turntable with Fidelity Research FR 64FX tonearm(used)
» Garrard 401 Turntable with Fidelity Research FR 24 mk2 Tonearm (Used) SOLD
» Luxman pd310 turntable + fidelity research fr64fx tonearm SOLD
