Chord CPA2200 Pre and SPM600 Power amplifiers (Used)
Chord CPA 2200 preamp and SPM 600 power amp is the best combination from Chord Electronics. A truly excellent British Made amplifiers from Chord Electronics UK.
Letting RM16,000. Interested, contact +65 90080098.
http://v2.stereotimes.com/post/chord-electronics-ltd.-spm-600-power-amplifier,-cpa2200-preamplifier
http://www.audioreview.com/product/amplification/preamplifiers/chord/cpa-2200.html
http://www.audioreview.com/product/amplification/amplifiers/chord/spm-600.html
SPM 600 Power Amplifier- OUTPUT POWER: 130W rms. per channel @ 0.05% distortion into 8W, 170W rms. Per channel into 4W, 200W rms into 2W. Thermal limitation only, 1 channel driven.
DYNAMIC HEADROOM: 200W rms per channel into 8W, 360W rms per channel into 4W. – 1 kHz, 20 cycles on, 480 cycles off. Peak pulses 8 milliseconds burst 75V peak (the equivalent of 400W per
channel peak into 2W)
FREQUENCY RESPONSE (8 OHMS) -1dB, 0.2Hz to 46KHz -3dB, 0.1Hz to 77KHz
FREQUENCY RESPONSE (4 OHMS)-1dB, 0.2Hz to 39KHz -3dB, 0.1Hz to 75KHz
SIGNAL TO NOISE RATIO better than -103dB, ‘A’ weighted two thirds power.
CHANNEL SEPARATION better than 95dB.
CONNECTION2 × gold-plated, fully balanced XLR sockets. 2 x gold-plated custom phono
sockets, unbalanced.
INPUT IMPEDANCE:100kW. Unbalanced/Balanced.
INPUT CAPACITANCE: OUTPUT IMPEDANCE: 0.02W
OUTPUT INDUCTANCE: 2.6mH
OUTPUT CONNECTIONS: 8 x 4mm rhodium binding posts (2 pairs Black, 2 pairs Red)
SLEW RATE: 70V per mS, 1KHz 20V square wave
CPA-2200 Preamplifier - HARMONIC DISTORTION
10Hz -90dB 10kHz -89dB
1kHz -91dB 20kHz -87dB
INTERMODULATION DISTORTION:-100dB all inputs
SIGNAL TO NOISE RATIO: -93dB all inputs except Video (-83dB)
CHANNEL SEPARATION: 10Hz 93dB 10kHz 91dB
1kHz 95dB 20kHz 89dB
CHANNEL BALANCE: 0.01dB
POTENTIOMETER PERFORMANCE: 0dB -20dB -60dB
0.5dB 0.2dB 0.24dB
11 secs. ±3 secs. for full travel of 300o
UNBALANCED INPUTS
Disc 1, Disc 2, Video, Radio, Tape 1 and Tape 2.
OUTPUTS
RCA phono style, gold-plated with Teflon dielectric insulation.
2 pairs balanced outputs (3-pin XLR) O/P 1 & 2.
1 unbalanced RCA phono style.
2 Tape outputs, unbalanced RCA phono style.
FREQUENCY RANGE: 2.5Hz – 200kHz (-3dB)
INPUT MAX: Disc 1 3.6V rms Radio 3.6V rms
Disc 2 3.6V rms Tape 1 3.6V Video 3.6V rms Tape 2 3.6V rms
NOMINAL GAIN: 1V AC In gives 2V AC Out
INPUT IMPEDANCE: 47kW
OUTPUT MAX: 15.6V rms balanced, 7.8V rms unbalanced
OUTPUT IMPEDANCE: 680W (short circuit protected)
0.5dB 0.2dB 0.24dB
UNBALANCED INPUTS
OUTPUTS
fordpiggy- Frequent Contributor
- Number of posts : 494
Re: Chord CPA2200 Pre and SPM600 Power amplifiers (Used)
Location Johor Permas Jaya
» Chord SPM600 poweramp Sold
» Chord CPA2200 preamp and SPM1000B poweramp (Used)
» The Chord Company Chord Power Chord - 1.5m (Used) SOLD
» Power amplifiers
» The Chord Company - Power Chord Mains Cable (2M) (New)(SOLD).
» Power amplifiers
