Crown T7 Power Amplifier
Crown T7 Power Amplifier Brand New. Now Selling At RM3,999. Free Shipping Within West Malaysia.
Crown T7
The four T series amplifier models (T3, T5, T7 and T10) are based on professional Crown technologies, with a simple and efficient amplification circuit, and an upgraded heat dissipation system designed to ensure professional performance day after day. For over 60 years Crown has focused on power amplifier technology research and innovation, and with the T series, Crown delivers a user-friendly installation with professional audio quality.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Specification:
Frequency Response 20Hz - 20kHz, +0/-1dB
Total Harmonic Distortion (THD) < 0.5%, 20 Hz - 20kHz
Intermodulation Distortion = / < 0.35% (from full rated output to -30dB)
Conversion Rate >10V/us
Voltage Gain 34.4dB
Damping Factor > 200 (8Ω, 10 Hz - 400 Hz)
Signal to Noise Ratio (below rated power 20 Hz to 20 kHz, A-Weighted) > 100 dB
Crosstalk -75dB at 1kHz, -59dB at 20kHz
Input Sensitivity 0.775V or 1.4V (rated power 8Ω)
Input Impedance 20kΩ Balanced, 10kΩ Unbalanced
Input Connectors Balanced XLR and one unbalanced RCA per channel
Output Connectors 4-POLE Speakon and a pair of binding posts per channel
Front Panel Components Power switch, channel gain control
Rear Panel Components Output mode switch: stereo, parallel, bridge, Input sensitivity switch: 0.775V or 1.4V
Power Indicator Blue and green two-color LED
Signal Indicator One green LED per channel
Clip Indicator One yellow LED per channel
Fault Indicator Red LED per channel , indicating that the channel is closed
Power cables Plug : 10A, 250V, Wire : CCC 3x1.5mm 2
Protection Protection against short circuit, no load, on / off noise, radio interference protection circuit
Ventilation Air convection mechanism
Cooling Internal air is forced to dissipate heat, fan cooling, rapid adjustment, temperature protection
Dimensions (w x h x d) 19” x 3.46” x 14.5” (482 mm x 88 mm x 369 mm)
Net Weight 39.9 lb (18.1 kg)
Shipping Weight 44.4 lb (20.1 kg)
Crown T7
Dual channel, 950W @ 4Ω
The Crown T series are professional-grade power amplifiers designed for entertainment venues, movie theaters, mobile performances, conference rooms and other commercial venues. Their compact design makes them perfectly suited for mobile use and entertainment venues with limited space.The four T series amplifier models (T3, T5, T7 and T10) are based on professional Crown technologies, with a simple and efficient amplification circuit, and an upgraded heat dissipation system designed to ensure professional performance day after day. For over 60 years Crown has focused on power amplifier technology research and innovation, and with the T series, Crown delivers a user-friendly installation with professional audio quality.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Specification:
Voltage Gain 34.4dB
- Number of posts : 1318
» Crown T3 Power Amplifier
» Crown T5 Power Amplifier
» Crown T10 Power Amplifier
» Crown XLi800 Power Amplifier
» Crown XLi1500 Power Amplifier
