Bowers and Wilkins B&W CM1 Bookshelf Speakers
Item: Bowers and Wilkins B&W CM1 Bookshelf Speakers
Condition: Item is in excellent condition. Comes with original grills
Price:RM2700 RM2400 or swap/topup
![Bowers and Wilkins B&W CM1 Bookshelf Speakers Bwcm1110](https://i.servimg.com/u/f88/14/76/78/48/bwcm1110.jpg)
![Bowers and Wilkins B&W CM1 Bookshelf Speakers Bwcm1210](https://i.servimg.com/u/f88/14/76/78/48/bwcm1210.jpg)
![Bowers and Wilkins B&W CM1 Bookshelf Speakers Bwcm1310](https://i.servimg.com/u/f88/14/76/78/48/bwcm1310.jpg)
![Bowers and Wilkins B&W CM1 Bookshelf Speakers Bwcm1410](https://i.servimg.com/u/f88/14/76/78/48/bwcm1410.jpg)
The partnership of a 130mm Kevlar
cone bass/midrange driver with a Nautilus
tube-loaded aluminium dome tweeter helps the CM1 handle musical detail with ease across the full frequency spectrum. Despite the size of the speaker, the CM1’s bass is always deep and under control thanks to the CM Series’ magnet and voice coil system technology, which keeps distortion to a minimum.
The quality of CM Series drive units has made it possible to use minimalist crossovers throughout the whole range. The resulting gentle transition between drivers avoids the unnaturally rapid changes in dispersion that bedevil more complex designs, while the high quality components, carefully chosen after exhaustive listening tests, ensure that as little as possible gets between you and the sound of the original recording.
All CM Series speakers come with aluminium driver trims. Grilles attach magnetically, so there are no unsightly grille-mounting features to spoil the clean lines of the speaker’s facade. For the finish, you can choose either one of two real-wood veneers in Rosenut or Wengé or highly polished Gloss Black.
Woven Kevlar
Crossover Tuning
Nautilus Tapering Tube
Flowport
Technical features Nautilus
tube loaded aluminium dome tweeter
Kevlar
brand fibre cone bass / midrange
Flowport![Bowers and Wilkins B&W CM1 Bookshelf Speakers 2122.png?v=2.2](https://cdn.jsdelivr.net/emojione/assets/png/2122.png?v=2.2.7)
Description 2-way vented-box system
Drive units 1x ø25mm (1 in) aluminium dome high-frequency
1x ø130mm (5 in) woven Kevlar
Frequency range -6dB at 45Hz and 50kHz
Frequency response 55Hz - 22kHz ±3dB on reference axis
Dispersion Within 2dB of reference response
Horizontal: over 60º arc
Vertical: over 10º arc
Sensitivity 84dB spl (2.83V, 1m)
Harmonic distortion 2nd and 3rd harmonics (90dB, 1m)
<1% 110Hz - 22kHz
Nominal impedance 8Ω (minimum 5.1Ω)
Crossover frequency 4kHz
Recommended amplifier power 30W - 100W into 8Ω on unclipped programme
Max. recommended cable impedance 0.1Ω
Height: 280mm (11 in)
Width: 165mm (6.5 in)
Depth: 276mm (10.9 in) including grille and terminals
Net weight 6.7kg (14.7 lb)
Cabinet - Real Wood Veneers Grille
https://www.soundstagenetwork.com/revequip/bw_cm1.htm
Price:
![Bowers and Wilkins B&W CM1 Bookshelf Speakers 00ae.png?v=2.2](https://cdn.jsdelivr.net/emojione/assets/png/00ae.png?v=2.2.7)
Woven Kevlar
Crossover Tuning
Flowport
Kevlar
Flowport
<1% 110Hz - 22kHz
» Bowers and Wilkins B&W CM1 Bookshelf Speakers
» Bowers & Wilkins (B&W) DM 601 Series 1 bookshelf speakers (SOLD)
» Bowers & Wilkins 705 S2 Bookshelf Speakers (PL) (SOLD)
» Bowers & Wilkins 706 S2 Bookshelf Speakers (PL) (Sold Out)
» Bowers & Wilkins B&W 705 Bookshelf Speakers (used), Now SOLD
