Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Empty Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle
Post by raymond88 Thu Jan 04, 2024 6:28 am
Item: Heco Victa Prime 302 Bookshelf Speaker
Condition: 8.5/10. Item is in excellent condition. No dents or scratches.
Price: RM1200 or swap/topup
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Hecovi12
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Hecovi10
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Hecovi11
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Hecovi13
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Hecovi14
HECO VICTA PRIME 302
Woofer and woofer-midrange with solid steel basket and high-grade, eightfold screwed trim ring
Bi-wiring/bi-amping option
Rubber spikes included
2-WAY SHELF SPEAKER, BASS REFLEX CONFIGURATION
HECO´s Victa Prime 302 is the larger of two shelf speakers in the series. Thanks to HECO´s tried and tested long-fibre kraft paper, the 170 mm bass-midrange driver always ensures sufficient stability and freedom from distortion in the critical frequency ranges. A 25 mm silk dome with ferrofluid cooling is also used in this compact speaker. It enables significantly enhanced power handling and improved transition to the midrange via its short horn attachment. The lightly rounded sides of the Victa Prime 302, which have been meticulously manufactured from layers of glued and moulded MDF panels, provide the speaker with a modern appearance. The extremely low-resonance structure offers optimum conditions for the chassis and bass reflex coordination.
EXCELLENT INTERACTION BETWEEN SOPHISTICATED TECHNOLOGIES
The quality of the woofer and midrange is crucial for the sound quality of a speaker. One element that comes under particular scrutiny here is the cone that is used for the driver. Long-fibre paper cones have been used for the bass-midrange units and their inverted dust caps. This is a material that is characterised by an excellent low weight/high damping ratio. A rich bass and transparent sound pattern is enabled in conjunction with powerful, high-quality ferrite magnets and heavy-duty voice coils. The mounting ring, which is screwed to the housing in six or eight places depending on the model, is now more solid. The 25 mm silk dome, which features ferrofluid cooling for improved power handling, has a short horn attachment for enhanced transition to the midrange. An amplitude and phase-optimised crossover is responsible for the harmonious interplay of the individual chassis.
HIGH QUALITY AESTHETICS AND EXCELLENT WORKMANSHIP IN EVERY DETAIL
The rounded sides have been meticulously manufactured from layers of glued and moulded MDF panels. The housing construction is thereby more stable with reduced resonance. This results in a low-resonance structure which offers optimum conditions for the chassis and bass reflex coordination. The floorstanding speakers are also equipped with a solid MDF base plate. The terminal area has been completely redesigned to ensure more space for the gold-plated and encapsulated connecting terminals. Damping rubber feet are included in delivery and the floorstanding speakers are also provided with height-adjustable metal spikes. The Victa Prime models, which are designed as bass reflex systems for a powerful and precise reproduction of the bass range, generate additional pressure via specially formed and screwed reflex ports.
HOME CINEMA ENJOYMENT AT A VICTA PRIME LEVEL
The magnetically shielded center speaker, which exhibits a double woofer configuration, and the subwoofer, which is equipped with its own power amplifier, enable home cinema enjoyment at a Victa Prime level. Besides the above mentioned features, all of the chassis are naturally also subjected to a fine tuning process with the help of our KlippelSpeakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 00ae.png?v=2.2 laser measuring and analysis system, after which they are coordinated in final listening and practical tests. The Victa Prime series once again demonstrates the enhanced possibilities of a fundamentally correct concept.
Item: PSB Alpha B1 Bookshelf Speaker
Condition: 9/10. Like new display set. With original box and packaging.
Price: RM750 or swap/topup
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Psbalp12
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Psbalp10
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Psbalp11
Meet PSB’s most acclaimed compact, budget-friendly speaker.
For decades, the Alpha B1 has been trusted by audio experts as the reference model for monitor speakers, making it one of the most reviewed bookshelf speakers ever. Starting from scratch at Canada’s national acoustic labs, the Alpha B1 is a true two-way design that uses a 5¼” (133mm) woofer made of metalized polypropylene, paired with a ¾” (19mm) aluminium dome tweeter to deliver crisp full-range sound with accurate and detailed bass. It uses the Alpha Series’ patented bass reflex design that utilizes the rear-firing port tube to improve efficiency and bring the bass response down below 60Hz.
¾” (19mm) Ferrofluid cooled aluminium dome tweeter with front waveguide
5¼” (133mm) Textured polypropylene mid/bass woofer with rubber surround
Bass reflex cabinet design with a rear-firing port
Enhanced tweeter for better dispersion
The Alpha B1 is equipped with a ¾” (19mm) aluminium dome tweeter that utilizes ferrofluid cooling to enhance high frequencies and deliver a layer of accurate sound with crisp detail. Coupled with a neodymium magnet for high sensitivity, a ferrofluid cooled tweeter also prevents dynamic compression and limits distortion when the volume starts to climb. The tweeter’s front waveguide is uniquely placed to smooth the response at the crossover for improved on and off-axis performance.
Cleanest, most natural bass possible
The B1’s all-new custom 5¼” (133mm) woofer is constructed from an injection-moulded polypropylene cone and has been redesigned to reduce breakup modes and lower distortion at full excursion. Hand-assembled and finished with an attractive metalized look, the innovative midbass woofer is supported with a dual-layer voice coil to deliver excellent midrange detail and distinct bass. The B1 is also a bass reflex design that utilizes the rear-firing port tube to control low frequencies with pinpoint accuracy.
Purpose-engineered for the ultimate system
Designed and engineered in Canada, PSB built the B1 with high-quality MDF to strengthen the cabinet and minimize unwanted vibrations that can compromise sound quality. Its plastic moulded front and rear baffles are internally ribbed and connected together to add rigidity to the speaker’s solid enclosure. Plus, the cabinet’s subtle curvature and high-quality woodgrain vinyl finish the speaker with class and elegance, while their compact size makes it easy to tuck the speakers into any room.
Patent bass reflex cabinet design with a rear-firing port
Aluminium detachable grilles perforated for acoustical transparency
Five-way gold-plated speaker binding posts speakers
High-quality woodgrain vinyl finish in Black Ash
Item: Bowers and Wilkins B&W CM1 Bookshelf Speakers
Condition: Item is in excellent condition. Comes with original grills
Price: RM2700 RM2400 or swap/topup
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Bwcm1110
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Bwcm1210
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Bwcm1310
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Bwcm1410
The partnership of a 130mm KevlarSpeakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 00ae.png?v=2.2 cone bass/midrange driver with a NautilusSpeakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 2122.png?v=2.2 tube-loaded aluminium dome tweeter helps the CM1 handle musical detail with ease across the full frequency spectrum. Despite the size of the speaker, the CM1’s bass is always deep and under control thanks to the CM Series’ magnet and voice coil system technology, which keeps distortion to a minimum.
The quality of CM Series drive units has made it possible to use minimalist crossovers throughout the whole range. The resulting gentle transition between drivers avoids the unnaturally rapid changes in dispersion that bedevil more complex designs, while the high quality components, carefully chosen after exhaustive listening tests, ensure that as little as possible gets between you and the sound of the original recording.
All CM Series speakers come with aluminium driver trims. Grilles attach magnetically, so there are no unsightly grille-mounting features to spoil the clean lines of the speaker’s facade. For the finish, you can choose either one of two real-wood veneers in Rosenut or Wengé or highly polished Gloss Black.
Woven Kevlar
Crossover Tuning
Nautilus Tapering Tube
Flowport
Technical features NautilusSpeakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 2122.png?v=2.2 tube loaded aluminium dome tweeter
KevlarSpeakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 00ae.png?v=2.2 brand fibre cone bass / midrange
FlowportSpeakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 2122.png?v=2.2
Description 2-way vented-box system
Drive units 1x ø25mm (1 in) aluminium dome high-frequency
1x ø130mm (5 in) woven KevlarSpeakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 00ae.png?v=2.2 cone bass / midrange
Frequency range -6dB at 45Hz and 50kHz
Frequency response 55Hz - 22kHz ±3dB on reference axis
Dispersion Within 2dB of reference response
Horizontal: over 60º arc
Vertical: over 10º arc
Sensitivity 84dB spl (2.83V, 1m)
Harmonic distortion 2nd and 3rd harmonics (90dB, 1m)
<1% 110Hz - 22kHz
Nominal impedance 8Ω (minimum 5.1Ω)
Crossover frequency 4kHz
Recommended amplifier power 30W - 100W into 8Ω on unclipped programme
Max. recommended cable impedance 0.1Ω
Height: 280mm (11 in)
Width: 165mm (6.5 in)
Depth: 276mm (10.9 in) including grille and terminals
Net weight 6.7kg (14.7 lb)
Cabinet - Real Wood Veneers Grille
https://www.soundstagenetwork.com/revequip/bw_cm1.htm
Item: NCA Laboratories Studio Monitor Speakers  Model 616V - RARE
Hand-made Super High Fidelity Speakers from California.
Condition: 7.5/10. Item is in very good working condition. No dents. Comes with speaker stands. With original grills.
Dimensions: 21" x 9 3/4" x 10"
Price: RM1600 RM1400 or swap/topup
NCA Laboratories Studio Monitor Speakers  Model 616V - RARE Nca110
NCA Laboratories Studio Monitor Speakers  Model 616V - RARE Nca210
NCA Laboratories Studio Monitor Speakers  Model 616V - RARE Nca310
NCA Laboratories Studio Monitor Speakers  Model 616V - RARE Nca410
NCA
Northern California Audio Laboratories  - Ultra High Definition LoudSpeaker
Clearwater’s parent company, NCA Laboratories is a well renowned loudspeaker manufacturer in the United States. Their Client list reads like a “Who’s Who” of the audio industry.
You have heard of most of their customers. Some of the most expensive loudspeakers in the world source their drivers and components from NCA Laboratories.
Item: Castle Severn Floorstander Speakers - Made In England
Condition: 8.5/10. Item is in excellent condition. Comes with original speaker grills and spikes
Price: RM1200 RM950 or swap/topup
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Castle16
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Castle18
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Castle17
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Castle19
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Castle20
Specifications:
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Type: 2-way, 2-driver loudspeaker system
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Enclosure: Bass reflex
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Tweeter: 1 x 25mm composite soft dome
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Bass/mid unit: 1 x 150mm driver
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Recommended amplifier: 25 – 110W
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Frequency response: 47Hz – 20kHz
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Sensitivity: 87dB
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Nominal impedance: 8Ω
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Finish: Black wood color
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Dimensions (W x H x D): 200 x 770 x 230mm each
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Weight: 16kg each
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Year: 1990s
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle 25aa.png?v=2.2 Made in England
Number of posts : 10300
Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle Empty Re: Speakers: Heco Victa Prime 302/PSB Alpha B1/B&W CM1/Model 616V/Castle
Post by raymond88 Thu Jan 11, 2024 8:39 am
Post by raymond88 Mon Jan 22, 2024 7:30 pm
Post by raymond88 Mon Jan 29, 2024 9:38 am
