BMB KSP15+ Karaoke Package
BMB KSP15+ Karaoke Package Brand New. Now Selling At RM19,999. Free Shipping Within West Malaysia.
BMB DAD-950
Standard power amplifier for PA speaker.
Selling point
BMB CSP-615
BMB Sound everywhere, PA type speaker Tuned for valious scene use.
Cabinet made of high quality birch plywood assembled by box joint.
The tough structure keeps outputting powerful sound stably.
Clear high frequency sound by fine-tuned diaphragm
Selling point
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
BMB WB-5000S
SYSTEM
Type Unidirectional dynamics UHF Wireless microphone system
Frequency Range 640Hz - 690Hz
Channel 200CH
Frequency Response 100Hz - 10Hz
Effective Distance 50m
Frequency Interval 250KHz
Frequency Width 50MHz
Frequency Oscillation Mode PLL Module locked loop design
Radio Frequency Sensitivity -90dBm
Total Harmonic Distortion < 5%
Dynamic Range >70dB
RECEIVER
SNR ≥50db
Frequency Stability ±5KHz
Signal Pick Up CPU controlled selection & pilot identification
Mute Mute & Lock Loop Circuit
Disply LCD
DC Input 12V DC ≥1000mA
Output Impedance 600Ω
Output 2 XLR Balance Socket + Unbalance TRS 6.3mm Socket
Dimensions (mm) 420(W) x 44(H) x 160(D)
MICROPHONE
Frequency Oscillation Mode PLL module locked loop design
Transmission Method CPU controlled carried wave & pilot identification
RF Stability ±5KHz
Display LCD+color backlit
Capsule Dynamic
Power Level Hight & Low
Power Supply 2 Pcs AA Battery
Weight 0.55KG
Dimensions (mm) 50(Φ) x 247(L)
BMB DAD-950 (SE)
Rating Output Power
1kHz THD=@1% 1200W×2CH(4Ω):stereo mode
950W×2CH(8Ω):stereo mode
1800W×1CH(8Ω);bridge mode
Frequency Characteristic(20Hz~20kHz、8Ω) ±0.3dB
THD(8Ω,1kHz) 0.02%
SN Ratio 105dB over
Damping factor(100Hz 8Ω) 250 over
Voltage Gain 40±2dB
Channel Separation(20Hz~1000Hz 8Ω) 85dB over
Input Impedance 20kΩ(balance)
Audio Input Connectors XLR type×2CH
Output Connectors Neutrik SpeakON NL4MP(1+/1-)
Screw type(+/-)
HPF Switch 50Hz/PASS
Ground Switch GND/FLOAT
AC Input 220V~240V(50/60Hz)
Power Consumption(1/8 Output Pink noise 8Ω) 3000W
Cooling Fans Automatic air volume control fans
Dimensions(mm) 482(W)×89(H)×423(D)
Weight 24.0kg
BMB CSP-615 [15"]
System Type Two-Way loudspeaker, bass reflex
Frequency Range(-10dB) *1 56Hz~20kHz
Frequency Response(±3dB) *1 95Hz~20kHz
Sound Pressure Level *2 97dB
Impedance 8Ω
Max Sound Pressure Level *3 124dB(Peak 130dB)
Power Capacity Continuous 600W, Program 1200W, Peak 2400W
Dimensions (W)443mm×(H)700mm×(D)463mm (17.4"×27.6"×18.2")
Shipping Dimensions (W)550mm×(H)825mm×(D)570mm (21.7"×32.5"×22.4")
Net Weight 33.5kg(73.7lbs)
Shipping Weight 39.3kg(86.6lbs)
Input Connectors Speaker Connector(4P)×2
Pole Mount Cap Φ36mm(1.4"), Depth 75mm(3.0")
Speaker unit LF Unit:390mm(15.4") Cone, 100mm(3.9") Voice Coil×1
HF Unit:37mm(1.5") Throat, 75mm(3.0")Voice Coil×1
Enclosure Construction 15mm(0.6") Plywood
Accessories Owners manual
Registration card
*1 Full space (4π) conditions
*2 1w1m on-axis, swept-sine in anechoic environment
*3 Calculated
BMB KSP-100
Mic Input: 4 systems
Audio Input: 3 systems (KARAOKE, AUX1, AUX2)
Video Input: 3 systems (KARAOKE, AUX1, AUX2)
Video Output: 3 systems
Output Connectors: 5.1 Channel systems (XLR type)
Sampling Rate/Bits: 44.1kHz / 24bits
Frequency Response: 20Hz ~ 20kHz
Control Connecters: USB (B type) RS-232C (DB-9 type)
LCD Display: 128x64 dots Black and White
DC Input: DC9V
AC Input: Adaptor (AC100V ~ 240V)
Dimensions (mm): 420(W) x 44(H) x 167(D)
Weight: 2.0kg
BMB WB-5000S
UHF Wireless Microphone System- By adopting a high-performance microchip and suppressing distortion, we realized a unique wireless quality microphone unique to BMB.
- It uses high-quality liquid crystal, it is easy to see in any installation situation.
- When the microphone dropped, The microphone will become mute.
It will not occur the Large volume Noise, when falling more than 20 cm. - New function that microphone automatically connect to receiver by shaking microphone. (WB-5000 / WM-500)
BMB DAD-950
DAD Series
Standard power amplifier for PA speaker.- Circuit safety protection will prevent damage in case of accident.
- Case size is standard 2U.
- Switch 2 type of output system. (Stereo / Bridge)
Selling point
- Designed for PA speaker.
- High power, 1800W x 1ch. (DAD-950)
BMB CSP-615
CSP Series
BMB Sound everywhere, PA type speaker Tuned for valious scene use.Cabinet made of high quality birch plywood assembled by box joint.
Selling point
- A new type of vocal and music mixing style. Not only for KTV, but also for Bar, Club, Restaurant, various scene.
BMB KSP-100
Highlight- PC Editor is provided to setup each sound parameter. (EQ, Comp, etc.)
- This model can create the best Karaoke sound for any room or hall utilizing sound editing software via computer.
- The voice effect feature - HANAMICHI - is pre-installed so the orchestra sound shifts from side to side while the singer stays in the center. (KSP-100)
- The Room Acoustic feature is installed to automatically adjust the sound field to all environments depending on the shape of the room and material of the walls, the floor and the ceiling. (KSP-100)
- An Anti-Feedback feature is used to ensure the best indoor feedback control.
- KSP-100 is made in Japan.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
BMB WB-5000S
SYSTEM
Channel 200CH
Dynamic Range >70dB
RECEIVER
SNR ≥50db
Disply LCD
MICROPHONE
RF Stability ±5KHz
Capsule Dynamic
Weight 0.55KG
BMB DAD-950 (SE)
Rating Output Power
THD(8Ω,1kHz) 0.02%
SN Ratio 105dB over
Voltage Gain 40±2dB
Screw type(+/-)
Weight 24.0kg
BMB CSP-615 [15"]
Impedance 8Ω
Registration card
*3 Calculated
BMB KSP-100
DC Input: DC9V
Weight: 2.0kg
- Number of posts : 1342
» Pro Ktv MK5 Karaoke Package
» BMB CSJ-06 Karaoke Package
» BMB CSJ-08 Karaoke Package
» BMB CSJ-10 Karaoke Package
» BMB CSJ-12 Karaoke Package
