KRK Ergo DAC, preamp and headphone amp with Lyngdorf Roomperfect
KRK Ergo DAC, preamp, headphone amp and room correction device with crossover. This uses Lyngdorf Roomperfect and is probably the cheapest way to get Roomperfect in your system. Can be fed with a balanced analog inputs on TRS or digital input via coaxial or Firewire. Outputs are balanced via TRS connections for either 2 pairs of speakers or 2 speakers and 2 subs. You can use this to create a corrected 2.1 or 2.2 system with a crossover by placing it between your preamp and power amp, or use it as a standalone preamp into monitors or a power amp.
Please note that to run the room correction software you will need to connect a PC or Mac to this with a Firewire connection. I have the software for Windows 7 which I can provide on a USB stick.
Comes with the original box, power supply and room connection microphone with cable. Condition 7/10.
RM850
![KRK Ergo DAC, preamp and headphone amp with Lyngdorf Roomperfect Krk110](https://i.servimg.com/u/f69/20/29/10/80/krk110.jpg)
![KRK Ergo DAC, preamp and headphone amp with Lyngdorf Roomperfect Krk210](https://i.servimg.com/u/f69/20/29/10/80/krk210.jpg)
![KRK Ergo DAC, preamp and headphone amp with Lyngdorf Roomperfect Krk310](https://i.servimg.com/u/f69/20/29/10/80/krk310.jpg)
RM850
pumba- New Member
- Number of posts : 10
Registration date : 2020-09-23
» SOLD Melos SHA-1 Preamp/ Headphone Amp (Used)
» Beresford TC-7520 DAC/headphone amp/preamp (New)
» Rudistor rp8 headphone amp/preamp
» HoHo DIY MPA2.5 preamp/headphone amp (New)
» AudioQuest Dragonfly Red - USB DAC + Preamp + Headphone Amp
