Garrard MRM 101 Phono Stage
Garrard MRM 101 phono stage for MM cartridge
Thoroughly restored and in clean condition
New RCA, grounding jack, power plug
Audition Welcome
240V
RM850
Audition and COD in Bukit Jalil
WhatsApp Ammar 0164358364
![Garrard MRM 101 Phono Stage Img_2112](https://i.servimg.com/u/f66/19/04/76/58/img_2112.jpg)
![Garrard MRM 101 Phono Stage Img_2110](https://i.servimg.com/u/f66/19/04/76/58/img_2110.jpg)
![Garrard MRM 101 Phono Stage Img_2111](https://i.servimg.com/u/f66/19/04/76/58/img_2111.jpg)
https://www.vinylengine.com/library/garrard/mrm-101.shtml
The MRM 101 (Music Recovery Module) is designed to remove the objectionable noises heard when a phono pickup meets a scratch on the record being played.
It is not intended to remove all noises associated with old, worn or generally dirty records.
Since these noises occur in an almost continuous manner, their detection could lead to the removal of a substantial proportion of the original recording.
The MRM contains a high quality stereo preamplifier with magnetic phono inputs.
This allows the MRM to be simply and directly connected to the amplifier 'aux' or 'tuner' inputs.
The scratch detection circuit recognises the whole waveform of the scratch and distinguishes it from the peaks of the recorded music.
In order to make the decision to remove the scratch, the channels are individually delayed by a few milliseconds without limiting the audio frequency range.
After recognising the scratch, a specially designed network isolates the signal for sufficient time for the scratch noise to pass out of the delay line.
Input: suitable for cartridges with an output of 0.7 to 2mV
Input impedance: 47k ohm
Dynamic range: greater than 100dB
Distortion: less than 0.1% THD
Channel balance: better than 2dB
Nominal output: 300mV RMS
Power supply: 120V AC 50/60Hz 7VA or 220/240V AC 50/60Hz 7VA
Dimensions: 378 x 298 x 71mm
Weight: 3.7kg
Audition Welcome
240V
RM850
Weight: 3.7kg
Ammar Mariti- New Member
- Number of posts : 17
Registration date : 2014-11-04
Re: Garrard MRM 101 Phono Stage
Enquire for special CNY price.
» Aesthetix Callisto Line Stage Pre-amp and IO Phono Stage
» Cyrus Phono Signature Phono Stage Made In England
» Clearaudio Smart Phono V2 Phono Stage (Made In Germany)
» Clearaudio nano phono V2, phono stage (SOLD)
» Phono Stage
» Phono Stage
