Lavry DA11 Stereo DAC
Item: Lavry DA11 Stereo DAC
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with
Price:RM2900 RM2600 or swap/topup
Description
Features like a USB input, programmable settings, infrared remote capability, and the proprietary >PiC< Playback Image Control make the DA11 more than just a great sounding digital to analog converter; Users of the DA11 experience a new dimension of control over their listening experience.
In keeping with the Lavry Engineering tradition of innovation in the pursuit of excellence, the DA11 combines customer-requested features with a flexible approach to controlling the stereo image. The patented >PiC< (Playback Image Control) allows the listener to adjust their position within the stereo sound field in a way that is unique to the DA11. Applications include adjusting the stereo width to create a headphone listening experience more like listening in a room with speakers or moving the “sweet spot” with asymmetrical speaker placement.
The DA11 includes a full complement of USB, XLR, RCA, and optical digital audio inputs to offer flexibility in using computer, network music, or stand-alone CD player sources, as well as studio equipment. Balanced and unbalanced output options are provided for ease in connection to a wide range of Hi-Fi as well as professional audio gear. High-quality XLR to RCA adapters are included for connection to RCA input equipment.
With the addition of infrared remote capability, the DA11 allows the listener to easily control important functions from the listening position with the added benefit of working with most universal remotes. The remote Mute function controls both headphone and main outputs, while a separate main output On/Off setting makes private headphone listening convenient.
Like the highly acclaimed LavryBlack DA10, the DA11 offers extreme transparency and musicality in DA conversion with the ability to control speaker volume using digitally controlled ANALOG volume circuitry. This allows the DA11 to be connected directly to a power amp or powered monitors without a preamp for the ultimate in “straight-wire” listening. With unparalleled precision in channel matching throughout the volume range, this feature allows the listener to easily reset the volume to a known level for consistent enjoyment with minimal signal degradation. Like all other programmable settings, the Volume setting is retained in memory when the power is turned “off.”
KEY FEATURES
Ultra-low jitter mode to minimize source degradation
Patented >PiC< Playback Image Control
Accepts input sample rates between 30kHz and 200kHz
Potentiometer-free digitally controlled analog volume circuitry
High power discrete headphone output
XLR, USB, RCA (Coaxial), and Optical (Toslink) digital inputs
Infrared remote control with user-supplied universal remote control
Power On/Off muting protection on Main and Headphone outputs
Balanced or unbalanced outputs with Polarity Inversion
Included XLR to RCA adapters for easy connection to RCA inputs
PERFORMANCE
Volume Control Precision:
Integral linearity (deviation from straight line) – better than 0.1dB
Differential linearity (step size) – better than 0.08dB
THD+N at max volume (volume = 56) – typical, 0.0008% FS, maximum 0.0013% FS
Test conditions: 20Hz – 20KHz, -3dBFS sine wave
22-22KHz BW at all possible settings and switch combinations. This also applies to operating the DA11 with the included XLR to RCA adapters.
Dynamic Range: -112dB typical, -110 dB minimum
Test conditions: Non-weighted
Range valid for all possible settings and switch combinations.
Drive Capability:
24dBu Balanced XLR output into 1K ohms at Volume = 56 or lower
21dBu Balanced XLR output into 600 ohms at Volume = 53 or lower
18dBu Unbalanced XLR output into 600 ohms at Volume = 56 or lower
18dBu Headphone into 100 ohms at Volume = 56 or lower *
18dBu Headphone into 50 ohms at Volume = 50 or lower *
Test conditions are input of -3dBFS at 1kHz with a reference of 24dBu @ 1kHz with no weighting applied. Output values are at 0dBFS instead of -3dBFS.
https://6moons.com/audioreviews/lavry/dac.html
https://www.headfonia.com/lavry-da11-review/
Price:
Description
KEY FEATURES
PERFORMANCE
Drive Capability:
» Lavry DA11 Stereo DAC
» Lavry DA11 DAC
» Lavry DA-11 (used)
» Lavry Engineering DA-11 (Black) DAC + Headphone amp
» NAD Monitor Series 1600 Stereo Preamp Tuner and 2700 Stereo Power amplifier (Used) SOLD
» Lavry DA11 DAC
