Naim DAC-V1 with Headphone Amp
Item: Naim DAC-V1 with Headphone Amp
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with original remote, manual and original box.
Price: RM3500 or swap/topup
![Naim DAC-V1 with Headphone Amp Naimda10](https://i.servimg.com/u/f88/14/76/78/48/naimda10.jpg)
![Naim DAC-V1 with Headphone Amp Naimda12](https://i.servimg.com/u/f88/14/76/78/48/naimda12.jpg)
![Naim DAC-V1 with Headphone Amp Naimda11](https://i.servimg.com/u/f88/14/76/78/48/naimda11.jpg)
![Naim DAC-V1 with Headphone Amp Naimda13](https://i.servimg.com/u/f88/14/76/78/48/naimda13.jpg)
Digital Inputs:
5 x S/PDIF (2 x coaxial BNC, 2 x optical TOSLINK, 1 x front panel mini-TOSLINK)
1 x USB Type-B (Asynchronous)
Analog Outputs:
2 x RCA Phono
1 x DIN (for NAIM amplifier connection)
Audio Resolution:
Maximum Resolution: 24-bit/192kHz
Digital-to-Analog Converter (DAC):
Burr-Brown PCM1704
Frequency Response:
10Hz – 20kHz (+/-0.1dB)
Total Harmonic Distortion + Noise (THD+N):
<0.002% (measured at 1kHz, -2dBFS)
Signal-to-Noise Ratio (SNR):
121dB (A-weighted)
Dimensions:
Height: 70mm (2.76 inches)
Width: 432mm (17 inches)
Depth: 301mm (11.85 inches)
Weight:
4.75 kg (10.47 lbs)
Power Consumption:
Typical use: 12W
Standby: <0.5W
Control:
Front panel display with rotary encoder
Remote control
https://homestudiobasics.com/naim-dac-v-1-review/
https://www.naimaudio.com/product/dac-v1
https://www.whathifi.com/naim/dac-v1/review
https://www.dedicatedaudio.com/products/naim-dac-v1-headphone-amplifier-with-digital-to-analog-converter
Digital Inputs:
Analog Outputs:
2 x RCA Phono
Audio Resolution:
Burr-Brown PCM1704
Frequency Response:
121dB (A-weighted)
Dimensions:
Weight:
4.75 kg (10.47 lbs)
Power Consumption:
Typical use: 12W
Standby: <0.5W
Control:
Remote control
» Naim HeadLine Headphone Amplifier (New)
» Naim Headline 2 headphone amp + NAPSC2 power supply
» Naim NAP 300/Naim NAC252/Naim Supercap2/Naim Superline/Teddy Supercap (ALL SOLD)
» Spendor s9e floorstand speaker +Naim full setup Naim nd5xs, nap200, nap250.2, nac202, stageline (phono), hicap, nspc, naim fraim, naim speaker cable,
