Bluenote Pamphili Phonostage
Italian designed and made phono preamp for MC and MM cartridges. Body is solidly built with heavy cylindrical aluminium to cut out vibration and complete shielding.
By the way, this phono preamp was used by Koetsu USA at one of the CES hifi show in Las Vegas.
Input Sensitivity
MC from 0.1mV - 0.5mV
MM from 0.6mV - 3mV
Gain
MC 70dB, MM 48dB
Loading
MC is *470ohm (factory set). Variable through replacing required loading resistors. No soldering required.
MM is 47Kohm. Variable through replacing resistors.
These are internal adjustment. Fully explained in the user manual.
*For simplicity of adjusting loading, i have used a high value resistors for the MC so one can just connect required loading resistor externally without having to open the unit. This is how i have been using it. Nevertheless once happy with the chosen loading one can then use that loading resistor for the internal connection.
For full spec pls refer to pic from the user manual
Comes with original box, packing and manual.
RM6,200
Tel: 017 - double eight double three 785.
![Bluenote Pamphili Phonostage Img_6413](https://i.servimg.com/u/f54/18/67/25/11/img_6413.jpg)
![Bluenote Pamphili Phonostage Img_6410](https://i.servimg.com/u/f54/18/67/25/11/img_6410.jpg)
![Bluenote Pamphili Phonostage Img_6412](https://i.servimg.com/u/f54/18/67/25/11/img_6412.jpg)
![Bluenote Pamphili Phonostage Img_6411](https://i.servimg.com/u/f54/18/67/25/11/img_6411.jpg)
Input Sensitivity
MM from 0.6mV - 3mV
Gain
MC 70dB, MM 48dB
Loading
RM6,200
BruceWayne- Frequent Contributor
- Number of posts : 269
Registration date : 2013-10-03
» BlueNote stibbert(MK2)(used)
» Bluenote Stibbert Tube CD Player (Used) Price Reduced
» Bluenote Stibbert Tube CDP (Used)
