Usher Reference 1.5 Power Amplifier (SOLD)
In good condition 8/10![:white_check_mark: ✅](https://cdn.jsdelivr.net/emojione/assets/png/2705.png?v=2.2.7)
Selling for RM6000 (SOLD)
Contact Peter 012-3820333
A Class A design, the R-1.5 employs massive heat sinks to cool the amp.
The R-1.5 amplifier is designed to drive any loudspeaker, producing warm, "tube like" sound quality. It has been constructed with premium parts, including metal film resistors and film capacitors, reinforcing Usher's reputation for high-quality manufacturing. High-power bipolar transistors, designed by Motorola, can handle sophisticated power and current requirements. And its massive AC power transformer works with a high-capacitive filtering system for the purest sound. Other features include Burrow-Brown OPA2134P Sound Plus Series op amps, bridging switch for mono block operation, terminals that accept both banana plugs and spades, optional balanced inputs and large handles on the front and rear panel.
8 Ohm : 150 Watts/channel
4 Ohm : 260 Watts/channel
Damping factor : >175 (single ended)
Circumgyration : >40V / uS
Power supply (4 Ohm) : >16A
Transient power supply : >75A
S/N ratio : 100 dB
Frequency (20Hz-20kHz) : - 0.25dB (20Hz-100kHz) : - 3dB
Weight: 37 kgs
Dimension (w x d x h ): 48 cm x 48 cm x 22.5 cm
![Usher Reference 1.5 Power Amplifier (SOLD) Img_8126](https://i.servimg.com/u/f85/19/90/02/08/img_8126.jpg)
![Usher Reference 1.5 Power Amplifier (SOLD) Img_8125](https://i.servimg.com/u/f85/19/90/02/08/img_8125.jpg)
![Usher Reference 1.5 Power Amplifier (SOLD) Img_8234](https://i.servimg.com/u/f85/19/90/02/08/img_8234.jpg)
S/N ratio : 100 dB
Weight: 37 kgs
Last edited by peterclting on Sat Mar 02, 2024 8:23 pm; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2698
» Usher R 1.5 Reference Power Amplifier (Used) SOLD
» Usher Audio R1.5 Power Amp & P307A Pre-amplifier (SOLD)
» Usher R 1.5 'Class A' Reference Power Amplifier (Used) sold
» Usher P-307A Pre-amplifier (Sold)
