Supra EFF-IXLR – Silver Plated Balanced Audio Interconnect Cables (Pair)
![Supra EFF-IXLR – Silver Plated Balanced Audio Interconnect Cables (Pair) Suprae10](https://i.servimg.com/u/f13/20/44/36/59/suprae10.jpg)
![Supra EFF-IXLR – Silver Plated Balanced Audio Interconnect Cables (Pair) Suprae12](https://i.servimg.com/u/f13/20/44/36/59/suprae12.jpg)
![Supra EFF-IXLR – Silver Plated Balanced Audio Interconnect Cables (Pair) Suprae11](https://i.servimg.com/u/f13/20/44/36/59/suprae11.jpg)
The pair is in very excellent condition. Comes with original box
Selling Price: RM680
Tel: 012-9956616
EFF-IXLR – Analogue balanced interconnect.
The above Supra EFF-I in balanced mode equipped with our Supra XLR patented fully shielded connectors designed for long service life in professional use. The connector features a durable clamping force cable strain relief integrated in the housing and the XLR standard quick lock fastener with button release for chassis mount. Suitable for use in any balanced transmissions from mid-/high-end home audio to pro-studio.
BEST BUY HI-FI CHOICE MAGAZINE
EFF-I is one of Supra´s most awarded products, not without good reason…
Like all the Supra Cables products, the EFF-IXLR offers ridiculously high-quality performance and workmanship for its price.
In designating the EFF a Best Buy, the esteemed British magazine Hi-Fi Choice made the following comments:
“immaculately assembled”
“…if there are any drawbacks to this cable it’s hard to find them.”
“…unusually capable and an obvious Best Buy.”
“This cable came out as an easy top choice…”
What HiFi? (U.K.), in giving the EFF their highest, 5-star ranking, was equally enthusiastic:
“This stellar cable offers a cohesive and organized sound, with boundless authority and great expression.”
The above Supra EFF-I in balanced mode equipped with our Supra XLR patented fully shielded connectors designed for long service life in professional use. The connector features a durable clamping force cable strain relief integrated in the housing and the XLR standard quick lock fastener with button release for chassis mount. Suitable for use in any balanced transmissions from mid-/high-end home audio to pro-studio. Simply the second best analogue interconnect cable we offer.
In order to minimize the skin-effect the EFF-I is designed in accordance with Equalized Frequency Flow (EFF) Technique. It is based on tube shaped conductors with a wall thickness of 0.20mm, which is well below the smallest skin depth within the Audio range. This allows the same resistance for all frequencies. The result is a transparent and exact reinforcement with clear room definition.
EFF-I – Our Multi-Test Winner
Flawless signal transfer of even the most subtle music details is always the goal. A traditional cable, e.g. included interconnects with the hardware or the supermarket “high-end”, simply cannot reach the level of desired refinement an audiophile expect.
There are electric properties that needs to be addressed prior to reaching the goal; capacitance, phase, skin-effect and shielding.
The purity of conductors, dielectric choice, plating quality is generally sub-standard even though they might appear high-end.
The skin-effect is the physical event forcing higher frequency signals flow closer to the conductor surface. This means that low and high frequency impedance are not equal and therefor affects the signal level and phase. It has a profound dynamic and clearly audible influence because an audio signal is in principle nothing but an infinite number of frequencies at an infinite number of levels.
In order to minimize the skin-effect, the EFF-I is designed according to our Equalized Frequency Flow (EFF) technique. Around a plastic core, the strands are wound forming a conductor tube, in turn forcing all frequencies through the same cross section area well tuned for the entire audible range.
The result is a maintained frequency response as from the source without any level changes like treble roll-off or phase shift. Further the strands are silver plated to provide for ultra-high frequencies and are insulated using PE, providing the lowest capacitance.
Finally there must not enter any RFI destroying all efforts to maintain original signal integrity and our aluminized PET foil is a high bandwidth efficient shield keeping noise outside.
EFF-I is one of Supra´s most awarded products, and not without good reason…
See all my cables here:
Thank you.
- Number of posts : 465
» Supra Cables SWORD-IXLR Anniversary Bifilar Wound Interconnect Limited Edition - 1m pair
» Supra EFF-IXLR Interconnect with XLR (Pair) - 1.5m pair
» (Sold) Supra eff-isl rca interconnect silver plated
» Supra EFF-IXLR Interconnect with XLR 2M (Closed)
