Aesthetix Atlas mono block
Mono amplifier: 300 watts per channel into 8 ohms; 600 watts per channel into 4 ohms.
• Amplifier has a built-in high-pass crossover: 6 dB / octave, 16 settings from 40 Hz to 200 Hz in approximate 10 Hz increments.
• Single-ended and balanced inputs provide extended compatibility.
• Direct input bypasses all crossovers and switching for ultimate purity.
• Bus technology reduces power supply impedance between output devices for more instantaneous current.
• Power supply uses two transformers and three chokes. The high current section uses a dedicated transformer and choke input power supply. The vacuum tube B+ power supply has choke input and is discretely regulated. The result is unequalled clarity and control.
• Cardas patented rhodium-plated binding post with single knob lockdown.
• All aluminum chassis construction assures durability.
• Stainless steel cover for transformers prevents magnetic fields from interacting with sensitive audio circuitry, preserving low level musical nuances.
Asking price: RM28K
Condition: rarely use, 8.5 without box
[color:e369=rgba(18, 18, 18, 0.75)]WA: 0192682559
[color:e369=rgba(18, 18, 18, 0.75)]Location: P. Jaya
Asking price: RM28K
tcaw65- Regular
- Number of posts : 95
Registration date : 2011-04-09
» Audionet Pre & Power Mono Blocks (one of the Mono Block not working) SOLD
» Atlas Element Integra (mono rca)
» Magnum MF 125 mono block ( used )8/10
» used cary 70 mono block
» audiolab 8000p mono block
