WiiM Amp + Wharfedale D310 Hi-Fi System Package
WiiM Amp + Wharfedale D310 Hi-Fi System Package Brand New. Now Selling At RM2,799. Free Shipping Within West Malaysia.
Small Yet mighty
Housed in a sleek aluminum shell, the compact WiiM Amp offers versatile placement options. Inside, premium components and innovative circuitry ensure robust, crystal-clear amplification. A custom-designed heatsink ensures optimal thermal performance. Don't let its compact design fool you – it packs 60 Watts per channel at 8 ohms, and 120 Watts per channel at 4 ohms. Transform your passive speakers including floor-standing, architectural, outdoor, or bookshelf, into smart audio powerhouses.
Stream Everything
You Love
Streamline your sonic exploration with the WiiM Home app. Say goodbye to app-hopping; this all-in-one interface connects you to a plethora of popular music streaming services like Spotify, iHeartRadio, Tidal, Amazon Music, Qobuz, Napster, Pandora, TuneIn, Deezer, and more.
Does It All Like Magic
Master your audio universe with the WiiM Home App. Stream from top music services and manage your system effortlessly, room by room. Adjust volume, sync speakers, save favorites, set alarms, and tweak settings—all in one place. Prefer your go-to music app? No problem, play straight from it. Plus, go hands-free with voice commands. Whether you're using Alexa, Google Assistant, or Siri, control is just a word away, even with the included voice remote.
Your Music Library
Everywhere
Plug your USB disk into the WiiM Amp and transform your home into a personal concert hall. Stream your digital music collection in studio-quality to multiple WiiM devices throughout your space. The WiiM Amp not only indexes your music library but also serves as an always-on media server, making your personal tunes accessible anytime, anywhere in your home.
Tailor-Made Audio
Endless Possibilities
Unlock a world of sound customization with the WiiM Amp. Whether you're integrating ceiling speakers, reviving vintage audio gear, or optimizing your TV's sound, our robust suite of EQ options has you covered. Choose from 24 preset settings, fine-tune with a 10-band graphic EQ, or dive deep with a 4-band parametric EQ—all easily accessible in the app. Plus, enjoy the freedom to set independent EQ profiles for each input source, be it HDMI, Optical, Line, BT, or Network. Craft your perfect audio landscape, room by room, source by source.
Superior Sound Quality
Experience sound like never before with the WiiM Amp. Our rigorous audio tests show that it delivers a stunningly clear and rich audio experience. With a Total Harmonic Distortion + Noise (THD+N) of just 0.002% (-93 dB) and 98 dB SNR at 5W, it's nearly flawless—meaning you hear the music exactly as the artist intended, without any distracting noise or distortion. Whether you're a casual listener or an audiophile, the WiiM Amp elevates your audio experience to new heights.
Home Theater Magic, Simplified
Elevate your entertainment experience effortlessly with the WiiM Amp's HDMI ARC port. Plug in your TV and immerse yourself in rich stereo sound for shows, movies, and video games. Craving that extra oomph? Simply add a powered subwoofer to take your audio to cinematic levels. With minimal setup required, the WiiM Amp offers a seamlessly integrated AV system that turns your living room into a home theater paradise.
The D310 speakers incorporate an advanced midrange/bass drive unit, using the latest generation of Wharfedale’s woven Kevlar cones, bonded to a lightweight high tech foamed polyether surround. The driver delivers clarity and dynamic musical expression, for a detailed performance from a low-cost speaker. The cone is driven by a super long throw voice coil motor system, for increased bass extension, with low frequency accuracy. The magnetic flux is controlled by a specially shaped pole plate that reduces inductance, ensuring distortion of bass frequencies remains at a minimum, while oversized ceramic magnets create high sensitivity and smooth response across the cone.
WFR Tweeter
The Wide Frequency Response tweeter was original developed in the Diamond 11 Series, and has been fine tuned for the D300 Series. The 25mm textile dome tweeter is built in its own cabinet, with fibre filling for damping. The tweeter is driven by an oversized ceramic magnet with a copper capped pole piece for flux control, and performs with a smooth and pure tone, producing defined high frequency detail.
Crossover and Cabinet
Wharfedale’s Advanced Software and Listening Iteration system has been used to carefully develop the new crossover to add emphasis on lifelike reproduction of voices and instruments. The crossover components use low loss polypropylene capacitors and laminated core inductors for the optimum signal transfer. The cabinets for the D310 speakers feature 28mm front baffles, profiled to reduce diffraction edge reflections from high frequencies. Inside the cabinet, critical bracing is employed on the panels to eradicate unwanted noise and the walls are lined with a specially developed fibre to absorb resonant sounds. The sound output by the speaker therefore remains free from external noise and colourations, to produce pure and delicate audio.
P-EQ Bass Reflex Port
The D310 speakers included the newly developed P-EQ Pressure Equalisation bass reflex port for deep and controlled bass. The bass frequencies are emitted through a downward firing port in the speaker base, sounding Omni-directionally into the room. This reduces the pressure differential between the high pressure port and the low pressure room, minimising turbulence and chuffing, whilst improving bass response and efficiency. The P-EQ bass port on the D310 creates the fundamental notes of bass instruments, to match the realism of the midrange and tweeter. With the down-firing port, the D310 speakers can also be placed closer to the wall than conventional speakers without affecting the bass response, making the speakers less obtrusive in a room, and more easily placed on shelves.
The D310 speakers offer a remarkable performance from a budget, compact speaker, with an impressive midrange and fluid high end detail, with an accurate and controlled bass from the P-EQ port. The D310s are available in Black, White, Walnut and Rosewood finishes.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Wiim Amp Streaming Amplifier
Dimensions:7.48” x 7.48“ x 2.48" (190 mm x 190mm x 63 mm)
Weight:1.84kg(4.1 lbs)
Colors : Space Gray, Silver
Finish : Aluminum
Controls :olume knob, play/pause, and more
LED : Status, Volume
Power :
60 Watts/channel at 8 ohms
120 Watts/channel at 4 ohms
Speaker Output: Stereo or dual mono sound
Home Theatre Audio Formats : Stereo PCM (Dolby Digital and DTS are not supported)
Audio Input : HDMI Arc, Optical, Line
Audio Output :
Passive Speaker Terminal
Subwoofer Output
Audio Output Quality:
SNR - 98 dB
THD+N - 0.002% (-92 dB)
Audio Format : P3, AAC, ALAC, APE, FLAC, AIFF, WAV, WMA, OGG
EQ : Preset, 10-band Graphics EQ, 4-band parametric EQ
Subwoofer Output : Auto-detecting cable insert, user-adjustable 30-200 Hz crossover
Power Supply : 100-240V 50/60Hz AC Power
NetworkI : EEE 802.11 b/g/n/ac Dual band, 10/100 Mbps LAN
Bluetooth :
BT 5.1
A2DP Sink and Source, AVRCP
BLE HID
Supported Streaming : ProtocolAirPlay 2, Chromecast, Spotify Connect,
TIDAL Connect, Alexa Cast, DLNA
Wharfedale D310
General Description 2-way bookshelf speaker
Enclosure Type bass reflex
Transducer Complement 2-way
Bass Driver 4"(100mm)
Black woven Kevlar cone
Full Range Driver 1"(25mm) soft dome
Sensitivity (2.83v @ 1m) 86dB
Peak Power Handling 20-60W
Peak SPL 86dB
Nominal Impedance 4Ω (compatible 8Ω )
Minimum Impedance 3.6Ω
Frequency Response (+/-3dB) 65Hz ~ 20kHz
Bass Extension (-6dB) 60Hz
Crossover Frequency 2.2kHz
Dimensions ( H x W x D ) 265 x 155 x (200+28)mm
Net Weight 4.0kg/pcs
WiiM Amp
Stream Elegance, Amplify BrillianceSmall Yet mighty
Stream Everything
You Love
Your Music Library
Everywhere
Tailor-Made Audio
D310
Midrange DriverThe D310 speakers incorporate an advanced midrange/bass drive unit, using the latest generation of Wharfedale’s woven Kevlar cones, bonded to a lightweight high tech foamed polyether surround. The driver delivers clarity and dynamic musical expression, for a detailed performance from a low-cost speaker. The cone is driven by a super long throw voice coil motor system, for increased bass extension, with low frequency accuracy. The magnetic flux is controlled by a specially shaped pole plate that reduces inductance, ensuring distortion of bass frequencies remains at a minimum, while oversized ceramic magnets create high sensitivity and smooth response across the cone.
WFR Tweeter
- Wharfedale D310 Bookshelf Speakers with 100mm Kevlar woven midrange driver and 25mm textile tweeter
- Midrange driver features oversized ceramic magnets and pole plate to minimise distortion
- Wide Frequency Response tweeter uses ceramic magnets to control flux
- 28mm front baffles with profiling reduces edge diffraction and reflections
- Pressure Equalisation bass reflex port features down-firing port for increased bass response
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Finish : Aluminum
Power :
Audio Output :
Subwoofer Output
SNR - 98 dB
Bluetooth :
BT 5.1
BLE HID
Wharfedale D310
Peak SPL 86dB
- Number of posts : 1368
» WiiM Amp + Wharfedale Diamond 220 Hi-Fi System Package
» WiiM Amp + Wharfedale D320 Hi-Fi System Package
» WiiM Amp + Wharfedale Diamond 12.0 Hi-Fi System Package
» WiiM Amp + Wharfedale Diamond 210 Hi-Fi System Package
» Wharfedale D330 + D310 + D300C Speaker Package (Sold Out)
