Bluesound Powernode Edge Hi-Res Music Streaming Amplifier
Item: Bluesound Powernode Edge Hi-Res Music Streaming Amplifier
Condition: Open Box set.
Price:RM2650 RM2500 or swap/topup
![Bluesound Powernode Edge Hi-Res Music Streaming Amplifier Blueso17](https://i.servimg.com/u/f88/14/76/78/48/blueso17.jpg)
![Bluesound Powernode Edge Hi-Res Music Streaming Amplifier Blueso16](https://i.servimg.com/u/f88/14/76/78/48/blueso16.jpg)
Bluesound POWERNODE EDGE Compact Wireless Music Streaming Amplifier
Add a little extra power with the POWERNODE EDGE, the perfect entry point into “just add speakers” HiFi for the streaming age, combining streaming sources, control, and amplification all in one place. Audiophile-grade componentry capable of up to 24 bits/192 kHz hi-res audio, and wireless multi-room capabilities with smartphone controls combine to make the POWERNODE EDGE a great ‘building block’ amplifier to start, extend or complete a hi-res streaming audio system of any size.
- Easily power a pair of passive speakers
- 40 Watts per channel of DirectDigital
amplification technology handling 24 bit/192 kHz files
- A state-of-the-art Quad-Core 1.8GHz ARM
Cortex A53 Processor
- HDMI eARC connectivity
- Digital optical and analog input options, subwoofer output, and Bluetooth
wireless headphone output
- Dolby
Digital decoding
- Dual-band Wi-Fi, Gigabit Ethernet and support for 2-way Bluetooth
aptX
HD
- Stream hi-res content from internet radio stations, cloud music services or your own local music players
- Intuitive control with the BluOS Controller app
- Elegant capacitive touch panel for quick-access controls (Play, Pause, Volume Up/Down, Previous/Next Track)
- Includes an easy-to-install, multi-orientation wall-mounting bracket
- IR remote learning capability – optional control using the RC1 Remote Controller
- Connect with the BluVoice skill to enable voice assistants like Alexa, Google Assistant and Siri to control Players around the home.
- AirPlay 2 lets you play music or podcasts from wireless stereo components throughout your house — all in sync.
SPEC SHEET
Supported Audio File Formats: MP3, AAC, WMA, WMA-L, OGG, ALAC, OPUS
Supported Hi-Res Audio File Formats: FLAC, MQA, WAV, AIFF, MPEG-4 SLS
Supported Multi-Channel Audio Formats: Dolby
Digital
Native Sampling Rates: up to 192 kHz
Bit Depth: 16-24
Audio Controls & EQ: BluOS Controller App
Signal-to-Noise Ratio: -91dBA
Distortion: THD+N, 0.008%
Amplification: DirectDigital![Bluesound Powernode Edge Hi-Res Music Streaming Amplifier 2122.png?v=2.2](https://cdn.jsdelivr.net/emojione/assets/png/2122.png?v=2.2.7)
Rated Power Output: 40W x 2 (8 Ohms)
IHF Dynamic Power: 80W (4 Ohms) / 50W (8 Ohms)
Minimum Impedance: 4 Ohms
Operating System: BluOS
App Controller OS: iOS, Android, Windows, macOS
Ethernet/LAN: Ethernet RJ45, Gigabit 1000 Mbps
Wi-Fi Built In: Wi-Fi 5 (802.11ac), dual-band
Bluetooth Quality: Bluetooth 5.0 aptX HD
IR Optical Built In: IR Sensor Built In - front panel with IR Remote Learning
IR Input: 3.5mm Jack
Optical/Analog Input: Combo - Mini TOSLINK/Stereo 3.5mm
HDMI Input: HDMI eARC
USB IN: Type A (Fat32 Formatted)
Price:
![Bluesound Powernode Edge Hi-Res Music Streaming Amplifier 00ae.png?v=2.2](https://cdn.jsdelivr.net/emojione/assets/png/00ae.png?v=2.2.7)
- Dolby
SPEC SHEET
Bit Depth: 16-24
» Bluesound Powernode Edge Hi-Res Music Streaming Amplifier
» Bluesound - PowerNode 2 - Amplifier Wireless Streaming Music Player - (NEW)
» Bluesound Powernode 2i Wireless Multi-Room Music Streaming Amplifier
» Bluesound Powernode 2i Wireless Multi-Room Music Streaming Amplifier (PL)(Sold Out)
