Onkyo P-308 Stereo Preamplifier (PL)
Onkyo P-308 Stereo Preamplifier (PL) Used In Excellent Condition. Now Selling At RM2,250. Free Shipping Within West Malaysia.
![Onkyo P-308 Stereo Preamplifier (PL) 380](https://i.servimg.com/u/f36/19/84/46/23/380.jpg)
![Onkyo P-308 Stereo Preamplifier (PL) 458](https://i.servimg.com/u/f36/19/84/46/23/458.jpg)
![Onkyo P-308 Stereo Preamplifier (PL) 546](https://i.servimg.com/u/f36/19/84/46/23/546.jpg)
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
![Onkyo P-308 Stereo Preamplifier (PL) Trade](https://2img.net/h/www.ericwiley.co.uk/wp-content/uploads/2016/09/trade.png)
Type Preamplifier
Input Sensitivity / Impedance Phono MC : 160 μ V/100 Ω, 220 Ω
Phono MM : 2.5mV/47k Ω, 100k Ω
CD, Tuner, Line, Tape play : 150mV/20k Ω
Rated output voltage / impedance Tape rec : 150mV/560 Ω
Output : 1 V, 6 V (maximum) / 160 Ω
Phono maximum allowable input
(THD0.05%, 1 kHz) MC:13mV
MM:210mV
Frequency characteristic MC : 4 Hz ~ 150 kHz + 0.2 -3dB
MM : 1.8 Hz ~ 170 kHz + 0.2 -3dB
CD, Tuner, Line, Tape : 0.8 hz to 170 khz + 0 to 3 db
Total harmonic distortion rate (20 Hz to 20 kHz
3 v output, Vol-30dB) MC : not more than 0.003%
MM : not more than 0.0008%
CD, Tuner, Line, Tape : 0.0005% or less
Intermodulation distortion factor (at rated output) Not more than 0.003% (SMPTE, 70 Hz : 7 khz = 4 : 1)
Signal-to-noise ratio (IHF-A filter
Input short) MC : 76 dB (320 μ V)
MM:90dB(5mV)
CD, Tuner, Line, Tpae : 106 dB
Tone Control (Vol-20dB) Bass : ± 10 dB (20 Hz)
Bass Selector Bass:450Hz(Boost/Cut)
ContraBass:200Hz(Boost)
Treble : ± 8 dB (20 kHz)
Filter High : 7 kHz, 6dB/oct.
Transient killer operating time Power on:7sec
Power off:100msec
AC outlet Power switch interlock : 2 systems, total 800W
Power switch not linked : 1 system, 200W
Pwer 100 VAC, 50Hz/60Hz
Power consumption 22W (Electrical Appliance and Material Control Law)
External dimensions Width 465x Height 103x Depth 403 mm
Weight 8.5kg
Onkyo P-308
This control amplifier is designed to provide serious digital support and simplify high purity transmission. Direct In - We intend to take direct out thoughts and adopt simple circuit configurations that are multi-functional. Line-type inputs such as CD inputs are selected by the Input Selector switch, then then directly to the master volume-flat amplifier through muting, balance volume, mode and more. In addition, the tone control uses a direct tone system that is composed of a passive element by using a part of the volume circuit, eliminating the amplifier for toning. In addition, direct wiring is thoroughly conducted at the shortest distance between the input and the output side. Equipped with 8 input selectors and a separate double REC selector for Tape1 only. It has two outputs and a MODE switch on each one so you can get outputs for 3D subwoofer or center channel playback. The Output2 also includes an independent output attendant for both the left and right balance volume. The circuit configuration uses a super servo amplifier configuration with twin FET input and twin push-pull output stages. In addition, it achieves excellent characteristics by injecting the beneficial LED bias in terms of temperature coefficient and generated noise, as a material that obtains a constant voltage of about 2 V at a relatively small current.![Onkyo P-308 Stereo Preamplifier (PL) 458](https://i.servimg.com/u/f36/19/84/46/23/458.jpg)
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Type Preamplifier
MM:210mV
MM:90dB(5mV)
Power off:100msec
Weight 8.5kg
www.stylelaser.com.my
- Number of posts : 1399
» Onkyo PR-SC886 7.1-Channel A/V Preamplifier SOLD
» Yamaha C4 Stereo Preamplifier (Used)
» Yamaha C-1 Stereo Preamplifier and Yamaha B-1 Stereo Power Amplifier (Used)
» Bryston BP-17 Stereo Preamplifier
» Bryston BP-16 Stereo Preamplifier (Used)
