Dali Oberon 7 Floorstanding Speaker (PL)
Dali Oberon 7 Floorstanding Speaker (PL) Used In Excellent Condition. Now Selling At RM4,650. Free Shipping Within West Malaysia.![Dali Oberon 7 Floorstanding Speaker (PL) B111](https://i.servimg.com/u/f36/19/84/46/23/b111.jpg)
![Dali Oberon 7 Floorstanding Speaker (PL) Dali-oberon-series-eisa-logo](https://media-dali.azureedge.net/5871/dali-oberon-series-eisa-logo.jpg?anchor=center&mode=crop&quality=90&width=181)
![Dali Oberon 7 Floorstanding Speaker (PL) Design-01](https://media-dali.azureedge.net/2268/design-01.png)
![Dali Oberon 7 Floorstanding Speaker (PL) Smc-01](https://media-dali.azureedge.net/1127/smc-01.png)
![Dali Oberon 7 Floorstanding Speaker (PL) Woofer-02](https://media-dali.azureedge.net/2283/woofer-02.png)
![Dali Oberon 7 Floorstanding Speaker (PL) Wide-dispersion-02](https://media-dali.azureedge.net/3567/wide-dispersion-02.png)
This large floor-standing OBERON 7 speaker features 2 x 7” wood fibre SMC based woofers and an oversized 29 mm ultra-lightweight soft dome tweeter.
This, combined with the large but elegant cabinet, delivers the very best in deep bass and large room performance. Despite its size, this speaker is surprisingly delicate and will impress with its ability to render any music style naturally and lifelike even at lower volumes. This makes the OBERON 7 perfect for almost any audio setup and any music or movie style.
With the OBERON 7, we have made it easy to integrate your loudspeakers into any room. Both the driver materials and geometry applied in the OBERON 7 has been selected to achieve a wide dispersion pattern in the listening area. The same principles have been applied in the design of the crossover.
As result, you will experience a well-integrated sound, even when listening at a significant off-axis angle. This is important as you are rarely seated directly in front of your loudspeakers when listening to music. An added benefit is seriously reduced harmonic distortion and diffractions causing frequency distortion, as these will always be stronger in an on-axis response. This is also the reason why all DALI speakers are not designed to be toed-in.
![Dali Oberon 7 Floorstanding Speaker (PL) Dali-o11](https://i.servimg.com/u/f36/19/84/46/23/dali-o11.jpg)
![Dali Oberon 7 Floorstanding Speaker (PL) Dali-o10](https://i.servimg.com/u/f36/19/84/46/23/dali-o10.jpg)
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
![Dali Oberon 7 Floorstanding Speaker (PL) Trade](https://2img.net/h/www.ericwiley.co.uk/wp-content/uploads/2016/09/trade.png)
DALI OBERON 7 SPECS
Product series OBERON
Frequency Range (+/-3 dB) [Hz] 36 - 26,000
Sensitivity (2,83 V/1 m) [dB] 88.5
Nominal Impedance [ohms] 6
Maximum SPL [dB] 110
Recommended Amplifier Power [W] 30 - 180
Crossover Frequency [Hz] 2,300
Crossover Principle 2-way
High frequency driver, Quantity 1 x 29 mm
High frequency driver, Diaphragm type Soft Textile Dome
Low frequency driver, Quantity 2 X 7"
Low frequency driver, Diaphragm type Wood Fibre Cone
Enclosure type Bass Reflex
Bass Reflex Tuning Frequency [Hz] 39.5
Connection Input Single Wire
Recommended Placement Floor
Recommended Distance From Wall [cm] 20 - 80
Dimensions With Base (HxWxD) [mm] 1015 x 200 x 340
Accessories Included Manual
Rubber Feet
Spikes
Front Grille
Weight [kg] 14.8
DALI OBERON 7
The floor-standing DALI OBERON 7 speaker is a true showcase of DALI ideas, traditions and inventions - all wrapped in an elegant and modern design. It redefines what is possible, both in audio quality and visual design, in its price range. The two 7" woofers and one oversized 29 mm ultra-lightweight soft dome tweeter delivers the very best in deep bass and large room performance. Despite its size, this speaker is surprisingly delicate and will impress with its ability to render any music style naturally and lifelike.![Dali Oberon 7 Floorstanding Speaker (PL) Dali-oberon-series-eisa-logo](https://media-dali.azureedge.net/5871/dali-oberon-series-eisa-logo.jpg?anchor=center&mode=crop&quality=90&width=181)
CONTEMPORARY DESIGN
The rounded edges and rustic fabric of these new DALI front grilles add a lighter and more contemporary visual look to the OBERON series. This look is enhanced by the elegantly shaped aluminium base mounted on the two floor-standing models.![Dali Oberon 7 Floorstanding Speaker (PL) Smc-01](https://media-dali.azureedge.net/1127/smc-01.png)
PATENTED SMC
The iron pole piece of the OBERON woofer magnet is crowned by a patented SMC disk - minimizing the negative effects of the iron. The use of the SMC disk greatly reduces mechanical distortion, which lowers third order distortion. This allows for a longer listening pleasure, a relaxed midrange and a surprising amount of detail for its price class.![Dali Oberon 7 Floorstanding Speaker (PL) Woofer-02](https://media-dali.azureedge.net/2283/woofer-02.png)
WOOD FIBRE CONE
The OBERON woofer features a wood fibre cone with a blend of fine grain paper pulp, reinforced with wood fibres, which creates a stiff, light-weight and well-behaving structure. In combination with a low-loss surround and spider suspension, this cone reproduces the micro details in the signal - unfiltered and with high accuracy.![Dali Oberon 7 Floorstanding Speaker (PL) Wide-dispersion-02](https://media-dali.azureedge.net/3567/wide-dispersion-02.png)
EASY TO POSITION
The driver materials, crossover design and geometry applied in the OBERON series has been selected to achieve a wide dispersion pattern. This ensures a well-integrated sound, even when listening at a significant off-axis angle. An added benefit is seriously reduced harmonic distortion and diffractions causing frequency distortion. This is why all DALI speakers are not designed to be toed-in.PRODUCT DETAILS
With the launch of the DALI OBERON loudspeaker series, we have picked the best elements from our current speakers and brought them together in a series that delivers on audio quality, looks and versatility.This large floor-standing OBERON 7 speaker features 2 x 7” wood fibre SMC based woofers and an oversized 29 mm ultra-lightweight soft dome tweeter.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
DALI OBERON 7 SPECS
Rubber Feet
Spikes
Front Grille
Weight [kg] 14.8
www.stylelaser.com.my
- Number of posts : 1399
» Dali oberon 5 floorstand speaker
» Dali Oberon 5 speakers
» Dali Oberon Wall (Sold)
» DALI OBERON 7 Floor Standing Speaker
» Dali Oberon 5 FloorStand Speaker SOLD
