Audioquest Chicago RCA To RCA Interconnect 1.5Meter
Audioquest Chicago RCA To RCA Interconnect 1.5Meter Brand New. Now Selling At RM689. Free Shipping Within West Malaysia.
There was no specific recipe for successfully dyeing a river. A bit of trial and error was required. Initially, over 100 pounds of dye was used, and the river stayed green for a week! In the second year, 50 pounds of dye kept the river green for three full days. In the third year, it was found that using 25 pounds of dye would turn the river green for a single day. Two years later, environmental concerns led to the formation of a new vegetable-based dye that produces a perfect sea of green and lasts for four or five hours—40 pounds of the stuff does the trick. Following suit across the nation, major canals, minor creeks, city blocks, drinking fountains, and even the Presidential Fountain at the White House are dyed green for St. Patrick’s Day—all thanks to the wonderful example set in Chicago.
FEATURES
SOLID LONG-GRAIN COPPER (LGC) CONDUCTORS
Solid Long-Grain Copper (LGC) allows a smoother and clearer sound than cables using regular OFHC (Oxygen-Free High-Conductivity) copper. Solid conductors prevent strand interaction, a major source of distortion. The surface quality is critical because a conductor can be considered as a rail-guide for both the electric fields within a conductor, and for the magnetic fields outside the conductor. LGC has fewer oxides within the conducting material, less impurities, less grain boundaries, and definitively better performance.
HARD-CELL FOAM INSULATION
Hard-Cell Foam (HCF) Insulation ensures critical signal-pair geometry. Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy. Some of this energy is stored and then released as distortion. Hard-Cell Foam Insulation is similar to the Foamed-PE used in our more affordable Bridges & Falls cables, and is nitrogen-injected to create air pockets. Because nitrogen (like air) does not absorb energy and therefore does not release any energy from or into the conductor, distortion is reduced. In addition, the stiffness of the material allows the cable's conductors to maintain a stable relationship along the cable's full length, producing a stable impedance character and further minimizing distortion.
DOUBLE-BALANCED GEOMETRY
Specifically designed for single-ended applications, Double-Balanced Geometry offers a relatively lower impedance on the ground for a richer and more dynamic experience. While many single-ended cable designs use a single path for both the ground and the shield, Double-Balanced designs separate the two for cleaner, quieter performance.
METAL-LAYER NOISE-DISSIPATION
It's easy to accomplish 100% shield coverage. Preventing captured radio-frequency interference (RFI) from modulating the equipment's ground reference requires AQ's Noise-Dissipation. Traditional shield systems typically absorb and then drain noise/RF energy to component ground, modulating and distorting the critical "reference" ground plane, which in turn causes a distortion of the signal. Noise-Dissipation "shields the shield," absorbing and reflecting most of this noise/RF energy before it reaches the layer attached to ground.
COLD-WELDED, GOLD-PLATED TERMINATIONS
This plug design allows for a connection devoid of solder, which is a common source of distortion. Instead of solder, the process employs a high-pressure technique. Because the ground shells are stamped instead of machined, the metal used can be chosen for low distortion instead of machinability.
DIRECTION-CONTROLLED CONDUCTORS
All drawn metal strands or conductors have a non-symmetrical, and therefore directional, grain structure. AudioQuest controls the resulting RF impedance variation so that noise is drained away from where it will cause distortion. The correct direction is determined by listening to every batch of metal conductors used in every AudioQuest audio cable. When applicable, arrows are clearly marked on the connectors to ensure superior sound quality. For most models of AQ cable, the arrows not only indicate the direction that optimizes metal-directionality as part of Noise-Dissipation, but also indicates non-symmetrical attachment of shield and GND in order to optimize full-system performance. A fundamental aspect of AudioQuest's multifaceted Noise-Dissipation technology, Direction-Controlled Conductors ensure induced noise is dissipated and drained properly.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Chicago
Every March 17 on St. Patrick’s Day, New York City merely paints a green line down the center of its Fifth Avenue parade route—a stunt easily pulled off by any city—but only Chicago dyes an entire river the perfect shade of emerald green to honor Irish culture. Why green? Thanks to Ireland’s lush vegetation, the island is often lovingly referred to as the Emerald Isle. To the Irish, a green display of pride is not to be taken lightly. In the United States, even those of non-Irish descent know to wear green clothing on St. Patrick’s Day, or else be playfully pinched by an Irish friend or colleague! But it’s one thing to don a green shirt or tie, another thing altogether to transform a 156-mile long river. Chicago’s Stephen M. Bailey, the man who orchestrated the transformation, boasted that he’d turn the River Chicago into the River Shannon (Ireland’s longest) for a day, and, eventually, he did.There was no specific recipe for successfully dyeing a river. A bit of trial and error was required. Initially, over 100 pounds of dye was used, and the river stayed green for a week! In the second year, 50 pounds of dye kept the river green for three full days. In the third year, it was found that using 25 pounds of dye would turn the river green for a single day. Two years later, environmental concerns led to the formation of a new vegetable-based dye that produces a perfect sea of green and lasts for four or five hours—40 pounds of the stuff does the trick. Following suit across the nation, major canals, minor creeks, city blocks, drinking fountains, and even the Presidential Fountain at the White House are dyed green for St. Patrick’s Day—all thanks to the wonderful example set in Chicago.
FEATURES
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
- Number of posts : 1323
» Audioquest Tower 3.5mm to 3.5mm Interconnect 1.5Meter
» Chicago/Chicago Greatest Hits (New/Sealed) RM 70
» Chicago - Chicago Transit Authority Lp
» Audioquest Cinnamon Lightning USB Cable 1.5Meter
» Audioquest Cinnamon Optical Cable 1.5Meter
