VAL JD-L1 Preamplifier and JD-845SE Monoblock Power Amplifier (sold)
![VAL JD-L1 Preamplifier and JD-845SE Monoblock Power Amplifier (sold) Star3](https://2img.net/i/fa/i/smiles/star3.png)
In good condition 8/10
![Like a Star @ heaven](https://2img.net/i/fa/i/smiles/star3.png)
Previously retailed for RM40k
uses 4x 6SN7 tubes
Runs on 2 individual tube rectified external PSU (1 for each channel)
Uses 1x 845, 1x 300B and 2x 6SL7 per mono block
Outputs 28 watts per channel
Everything here is milled from solid solid material.
The preamplifier including power supply is also implemented in a complete double-mono design. The stabilization of the anode voltage and the operating voltage is designed using tube technology.
Grid potentiometers with closely selected fixed resistors ensure perfect control and channel equality.
The preamplifier offers 4 high level inputs and 2 pairs of outputs (1 x low for horn systems, and 1 x high for normal speakers).
The circuitry of the power amplifiers relies on a moderate overall negative feedback to achieve an adequate damping factor.
Additional circuit tricks enable a very low level of overall distortion.
Technical data and most important features:
• Continuous power 2 x 28 watts at K-2+3= < 1%
• Peak power 2 x 32 watts
• Input impedance 100k Ohm
• Input sensitivity 400 mV rms for 4 watts
• Input circuit 2 x SRPP (extremely low distortion)
• Driver stage 300 B and 845 have DC heating
• Output transformers with 4, 8 and 16 ohms
• Internal resistance approx. 1 ohm at 8 ohm output
• Fixed grid voltage supply for 845
• Extremely low-resistance (hard) power supply
• High voltage and mains transformer separated
• Dossel screening, operating voltage for the tubes 845 approx. 900 V and for the 300B at approx. 400 V
• Special 50 Hz transformers
• Vibration protection against high frequency interference
• Only one film capacitor in the entire signal path
• Cerafine electrolytic capacitors in the power supply
• Sound-defining driver and power amplifier circuit based on a model from the 1940s
• Pulse-stable dimensioning thanks to small internal resistances of the individual amplifier stages
![VAL JD-L1 Preamplifier and JD-845SE Monoblock Power Amplifier (sold) Img_8932](https://i.servimg.com/u/f85/19/90/02/08/img_8932.jpg)
![VAL JD-L1 Preamplifier and JD-845SE Monoblock Power Amplifier (sold) Img_9111](https://i.servimg.com/u/f85/19/90/02/08/img_9111.jpg)
![VAL JD-L1 Preamplifier and JD-845SE Monoblock Power Amplifier (sold) Img_9110](https://i.servimg.com/u/f85/19/90/02/08/img_9110.jpg)
![VAL JD-L1 Preamplifier and JD-845SE Monoblock Power Amplifier (sold) Img_9112](https://i.servimg.com/u/f85/19/90/02/08/img_9112.jpg)
Last edited by peterclting on Sun May 12, 2024 4:03 pm; edited 1 time in total (Reason for editing : SOLD)
- Number of posts : 2699
» [SOLD] Sony TA-E2000ESD Digital Processing Control Amplifier (Preamplifier), Sony TA-N330ES Power Amplifier, Sony TA-N220 Power Amplifier (All Used) [SOLD]
» Sold - Bryston 7B SST monoblock power amplifier (Used)
» Marantz MA-500 Monoblock Power Amplifier (Used) SOLD
» NAD 214 Bridged Monoblock Power Amplifier (sold)
» VTL MB 450 signature monoblock power amplifier (Used)SOLD
