Swiss Digital Fuse Box
Swiss Digital Fuse Box Empty Swiss Digital Fuse Box
Post by SgLiveAcoustics-AikHinFat Sun May 05, 2024 10:26 pm
For Malaysia inquiry please whatsapp Jordan +60 18-772 6629 if you would like to purchase these products
For Singapore inquiry please whatsapp Robert +65 92383607 if you would like to purchase these products
Our customer with a 100k hifi system setup added two Swiss Digital Fuse Box to his system, you can listen to it for yourself the significant differences before and after adding in our personal website, instagram, facebook
Personal Website - sgliveacoustics
Instagram - sgliveacoustics
Facebook - Sg Live Acoustics
Both our home audio hifi and headphones customers have been raving that they noticed a significant improvement in their sound systems after using our two best selling product, which is Puron AC Power Conditional and Swiss Digital Fuse Box respectively. They are pleasantly surprised that a product in this price range can have such significant impact.
SOUND QUALITY:
The Swiss Digital Fuse Box enhances the performance of the Hi-Fi setup components, making them operate as if there were no constraints on power. The resulting sound is characterized by its openness and lack of restrictions across the entire audio frequency range. It possesses a dynamic, intricate, and well-defined quality, while also evoking a sense of harmony and wholeness. It is as if the Hi-FI setup components can now unleash their complete potential in terms of frequency and harmonics.Swiss Digital Fuse Box (SDFB) is non-sacrificial overcurrent protection device that serves as a replacement for fuses in audio equipment.*NOTE you must use the same Ampere Swiss Digital Fuse Box to the component that you are connecting to.
HOW TO USE IT?
These things have two separate parts that work together:
1) The SDFB is inserted as the middle of a chain created between an audio component and the electrical outlet from which it draws power
2) a solid, cylindrical metal slug (referred to as a “Sluggo”) which is the same size as the typical fuse. To install a SDFB, first, with your component off, plug its power cable into the AC socket on one end of the box, and on the other end of the box there is a male IEC connector (C14) which you connect to an outlet using another power cable or an adapter. Once the box is connected to a live electrical line, it will go through a brief setup period, and after maybe 8-10 seconds, you’ll hear a clicking sound and the small green LED will stay lit, indicating that charge is now allowed to flow through the box. The second and final step, with the component still off, is to replace the fuse(s) with a Sluggo. The SDFB comes with a Standard Copper Sluggo. You can then turn the component on. Don’t replace a fuse with a Sluggo without the SDFB in place because you’ll have no overcurrent protection and you’ll incur the risk of severely damaging your component and/or having a catastrophic fire in the even of a short circuit or other overcurrent scenario.
Swiss Digital Fuse Box Comes With Standard Copper Sluggo:
1A, 2A, 3A, 3,15A, 4A, 5A, 6.3A, 8A, 10A – 530 SGD / 1862 RM
You can swap out the regular copper sluggo and upgrade with these alternatives, which are priced as follows:
Super Sluggo Copper In Gold Immersion: (Our recommendation)(Additional improvement of at least 20%)
Length 5x20mm – 44 SGD / 154 RM
Length 6x32mm – 44 SGD / 154 RM
Supper Duper Sluggo Tellurium Copper with Rhodium Plating:
Length 5x20mm – 267 SGD / 938 RM
Length 6x32mm – 401 SGD / 1409 RM
LISTEN TO BELIEVE – We invite everyone to visit our shop! We strongly believe in personal experience, trying something out yourself than to take online reviews and word for it.
Number of posts : 3
Location : 34 Upper Cross St, #02-152 Block 34, Singapore 050034
Registration date : 2024-05-04
https://sgliveacoustics.com/
