Paradigm signature S8/V3 (pre-owned)
Interested pls call Eddy 6012-2882691
Paradigm Signature S8/V3 Floor Standing Speakers
SPECIFICATIONS
SPECIFICATIONS
DESIGN | 6-driver, 3-way floorstanding |
CROSSOVER | 3rd-order electro-acoustic at 2.0 kHz; 2nd-order electro-acoustic at 230 Hz (bass drivers) |
HIGH FREQUENCY DRIVER | 25-mm (1 in) P-Be:tm: dome, ferro-fluid damped / cooled, rear damping chamber with ARB:tm: fins and integrated heatsink, dual super-neodymium ring magnets, die-cast heatsink chassis, IMS/SHOCK-MOUNT:tm: |
FREQUENCY RESPONSE ON-AXIS | ±2dB from 39 Hz - 45 kHz |
FREQUENCY RESPONSE 30° OFF-AXIS | ±2dB from 39 Hz - 20 kHz |
MIDRANGE FREQUENCY DRIVER | 178-mm (7 in) Co-PAL:tm: cone, ferro-fluid damped / cooled, ATC:tm: chambers, 38-mm (1-1/2 in) dual-layer voice-coil, super-neodymium ring magnets, AVS:tm: die-cast heatsink chassis, IMS/SHOCK-MOUNT:tm: |
LOW FREQUENCY DRIVER | Four 178-mm (7 in) mineral-filled polypropylene cones, overmolded NLC:tm: surrounds, 38-mm (1-1/2 in) four-layer long-excursion voice-coils, massive hard ferrite magnets, AVS:tm: die-cast heatsink chassis, IMS/SHOCK-MOUNT:tm: |
SENSITIVITY ROOM / ANECHOIC | 92 dB / 89 dB |
LOW FREQUENCY EXTENSION | 24 Hz (DIN) |
SUITABLE AMPLIFIER POWER RANGE | 15 - 500 watts |
MAXIMUM INPUT POWER | 250 watts |
IMPEDANCE | Compatible with 8 ohms |
FINISHES | Cherry, Piano Black |
DIMENSIONS HXWXD | 48.5" × 8.5" × 20.5" (123.2cm × 21.6cm × 52.1cm) |
WEIGHT | 100 lbs. (45.3 kg) |
eddyslb9ng- New Member
- Number of posts : 3
Registration date : 2024-05-22
» Paradigm reference and signature speakers (new )
» Paradigm Signature S6 V2 and Signature C1 V3 CLOSED
» Paradigm Signature S2sold
» Paradigm signature s8/v3 speakers
» Paradigm Signature S1 V3 CLOSED
