Bel Canto 3.7 DAC with Bel Canto VBL1 power supply unit - price reduced
![:white_check_mark: ✅](https://cdn.jsdelivr.net/emojione/assets/png/2705.png?v=2.2.7)
In good condition 8.5/10
Complete with Original Remote and box.
Single owner unit.
Bel Canto's DAC3.7 offers full system control and a range of features, including an analog input.
With a dedicated volume control, the DAC3.7 can also be used as a preamplifier. The Bel Canto Dual-Differential DAC3.7 Control Center boasts an impressive dynamic range of 126dB, along with Bel Canto's proprietary digital-to-analog converters.
Equipped with five 24/192 digital inputs, high-speed ST fiber, and a 24/192 ADC analog input, the DAC3.7 manages all your audio sources, including an analog input for a phono preamplifier or home theater bypass.
The front panel features a multifunctional control knob for input selection and volume control for both the "main source" and the front panel headphone jack.
The dedicated DAC/amplifier for the headphone jack optimizes the signal path. A clear and user-friendly display allows you to check balance, phase, rename inputs, and turn off unused inputs.
At the core of the DAC3.7 is the 'jitter-elimination' Master Reference Ultra-Clock circuitry, reducing jitter from all sources below the audible limit.
The 24-bit digital volume control maintains transparency and accuracy throughout its range.
Custom 0.1% audio quality resistors, Class-A output circuitry, and a low-noise power supply care housed in a rugged all-steel chassis to prevent mechanical resonance.
The internal VB supply, powered by the Bel Canto VBL1 virtual battery supply, features 400,000 uF of filter capacitance and ultra-low noise isolated switching for the analog section, preventing current distortion in the sensitive signal path.
Specification
DAC
Digital Section:
Maximum Data Input Rate: 24bit Data at 192KS/s: AES XLR, SPDIF BNC/RCA, ST Fiber, TOSLINK
Master Clock Jitter: 70 femtoseconds RMS, 100Hz-1MHz
Analog 24/192 DAC Section:
Maximum Output: 5.5 Vrms balanced XLR, 2.5 Vrms RCA
Output Impedance: 200 ohms balanced XLR, 100 ohms RCA
Frequency Response: 20 Hz-20 KHz, +/- 0.25dB
THD+N: <0.0015%, 5.5Vrms balanced out, 1KHz
Output Noise: 3uVrms A-weighted 20Hz-20KHz
Dynamic Range: 126dB A-weighted 20Hz-20KHz
Analog 24/192 ADC Section:
Maximum Input: 2.5 Vrms RCA
Input Impedance: 12K ohms RCA
THD+N: 0.003%, 2.5Vrms in, 1KHz
Dynamic Range: 110dB, A-weighted 20Hz-20KHz
General:
Power Usage On: 8W
Power Usage Off: 0.0W
Power Requirement: 12VDC
Dimensions: 216 mm W x 318 mm D x 88 mm H
Weight: 6.5 kg
VBL1 PSU
Maximum Output: 12VDC at 0.8A
Output Voltage: 12VDC +/- 5%
Output Voltage Noise: <27 Microvolts RMS, un-weighted 0 Hz – 100 KHz
Power Usage On: 10W typical
Weight: 6.5 kg
![Bel Canto 3.7 DAC with Bel Canto VBL1 power supply unit - price reduced Img_9328](https://i.servimg.com/u/f85/19/90/02/08/img_9328.jpg)
![Bel Canto 3.7 DAC with Bel Canto VBL1 power supply unit - price reduced Img_9327](https://i.servimg.com/u/f85/19/90/02/08/img_9327.jpg)
![Bel Canto 3.7 DAC with Bel Canto VBL1 power supply unit - price reduced Img_9329](https://i.servimg.com/u/f85/19/90/02/08/img_9329.jpg)
Last edited by peterclting on Wed Jun 19, 2024 9:07 pm; edited 1 time in total (Reason for editing : Price reduced)
- Number of posts : 2698
» Cyrus 2 PSX Power Supply Unit Only (Used)
» 12V AC Power Supply Unit (SOLD)
» Nva dacon dac unit + nva psu power supply
» LHY 12V AC Power Supply Unit (SOLD)
» Linear power supply unit (5V)- sold
