Bel Canto M300 Monoblocks Power Amplifier - 1 pair (Used)
Bel Canto M300 Monoblocks Power Amplifier - 1 pair (Used) Empty Bel Canto M300 Monoblocks Power Amplifier - 1 pair (Used)
Post by raymond88 Mon Jan 17, 2011 11:14 am
Item: Bel Canto M300 Monoblocks Power Amplifier - 1 pair
Condition: 8.5/10. In excellent condition.
Price: RM4450 or can swap with your equipments
Contact: Raymond 012-3816611
Bel Canto M300 Monoblocks Power Amplifier - 1 pair (Used) Belcan10
Bel Canto M300 Monoblocks Power Amplifier - 1 pair (Used) Belcan11
Some information:
The audio amplifier is the engine of the audio system. It must provide the power to drive the loudspeaker motor. The amplifier has huge power gain: from micro-watts of input power to 100’s of watts of output power the audio amplifier must do its job with ease and competence.
Key issues that must be addressed in a high performance audio amplifier are:
  1. Power supply design defines the performance limit of the amplifier, fully regulated power supplies provide the standard for fidelity.
  2. True balanced operation improves the signal fidelity under load.
  3. Balanced input insures that the large output/input power ratio does not corrupt the input signal fidelity.
  4. Low output stage impedance, especially at low frequencies, insures maximum control of the loudspeaker driver.
  5. Comprehensive protection circuit that is outside the signal path is critical to protecting both the amplifier and loudspeaker.
  6. A short, simple, signal path with a minimum of output devices leads to a better audio performance.
All of the Bel Canto e.One amplifiers are designed to optimize performance of all of these criteria. The M300 provides ground breaking performance in a compact, true mono chassis design with 300 watts of power. The M300 amplifier channel has its own fully regulated switching power supply, true balanced operation, 4 ohm drive capability and 111dB of dynamic range.
M300 amplifiers in your system will sound like you are connected directly to the music source, the loudspeaker and amplifier effectively disappear in the large and compelling sonic picture. Fidelity and signal clarity is unmatched from the lowest audio frequencies through to the sweetest high frequencies. The utter mid-range clarity especially allows the music to communicate as never before.
Discover what this remarkable amplifier technology can do for your audio system.
Bel Canto M300 Monoblocks Power Amplifier - 1 pair (Used) Prod_e10
Bel Canto M300 Monoblocks Power Amplifier - 1 pair (Used) Prod_e11
  • Power output: 300W into 4 ohms, 150W into 8 ohms
  • Minimum load: 4 ohms
  • Frequency response: +/- 0.5dB 20Hz-20kHz, all loads
  • THD+N: 0.01%, 1W, 1kHz, 4 ohms
  • IMD (CCIF): .0.002%, 1W, 14:15kHz, 4 ohms
  • Output noise: 90uVRMS A-weighted 10Hz-20kHz
  • Voltage gain: 27dB (single ended or balanced input)
  • Damping factor: >1000
  • Output Impedance at 100Hz: <8 milliohms
  • Dynamic range: 111dB
  • Input voltage for maximum output: 1.5Vrms
  • Input connections: Single-ended (RCA) or balanced (XLR)
  • RCA input impedance: 10Kohms
  • Balanced input impedance: 20Kohms
  • Output connections: WBT 5-way safety binding posts
  • Size: 8.5" x 3" x 12" (WxHxD)
  • Weight: 9 lbs.
Website info:
http://www.belcantodesign.com/Belcanto_eOne_M300_Mono_Audio_Power_Amplifier.html
http://www.positive-feedback.com/Issue26/belcanto_m300.htm
http://www.6moons.com/audioreviews/bcdtrio/trio.html
http://www.belcantodesign.com/pdfs/UG_eOneS300_M300.pdf
Please se my other equipments at: www.mudah.my/hifi-junction
Thank you very much.
Number of posts : 10076
