Eminent Technology LFT-8A speakers
Eminent Technology LFT-8A speakers Empty Eminent Technology LFT-8A speakers
Post by advance audiophile Thu Apr 07, 2011 9:51 pm
Description :
The Eminent Technology LFT-8 is the firm’s first hybrid loudspeaker using Planar Magnetic transducers combined with a low Q 8" woofer in a sealed enclosure. The magnetic drive principle developed by Eminent Technology for the LFT speaker series is unique. As the diaphragm of the speaker moves between the magnets following an audio signal, the magnetic field remains constant. In a way, it is the magnetic equivalent of a push-pull electrostatic loudspeaker, except that it requires no step-up transformer or bias voltage and the audio signal is applied directly to the diaphragm.
Specifications :
Power Requirements............................75 Watts minimum
Sensitivity...........................................84 dB (pink noise, 20 - 20kH) at 1watt/1 meter (2.83 V)
Frequency Response...........................25 Hz-20 kHz ±4 dB (typical room)
Phase Accuracy..................................± 20 100 Hz -31 kHz
High Frequency Level...........................Flat, - 6dB, -12dB at 20kHzsmooth roll off
Impedance..........................................8 Ohm rating
Maximum SPL....................................105 dB at 1 meter
General
Weight...............................................90.5 lbs. Each
Dimensions(w x d x h).........................13 x 1 x 60 inch
Miscellaneous :
Made in.............................................USA
Selling at RM8800.00 only. Call 0123282993.Eminent Technology LFT-8A speakers Eminen10Eminent Technology LFT-8A speakers Eminen11
advance audiophile
Number of posts : 602
