Eminent Technology LFT-8A Speakers
Eminent Technology LFT-8A Speakers Empty Eminent Technology LFT-8A Speakers
Post by advance audiophile Tue Apr 19, 2011 9:04 am
Eminent Technology LFT-8A Speakers Eminen11Eminent Technology LFT-8A Speakers Eminen10This firm's first hybrid speaker uses ribbon transducers combined with a dynamic 8-inch sealed-cabinet woofer
The Eminent Technology LFT-8 is the firm’s first hybrid loudspeaker using Planar Magnetic transducers combined with a low Q 8" woofer in a sealed enclosure. The magnetic drive principle developed by Eminent Technology for the LFT speaker series is unique. As the diaphragm of the speaker moves between the magnets following an audio signal, the magnetic field remains constant. In a way, it is the magnetic equivalent of a push-pull electrostatic loudspeaker, except that it requires no step-up transformer or bias voltage and the audio signal is applied directly to the diaphragm.
In order to obtain a uniform driving force over the entire surface area of the diaphragm, a low mass foil/mylar diaphragm is used with conductor traces etched (like a circuit board) with high resolution. The large surface area of the midrange driver gives good power handling. A lightweight diaphragm is utilized for the high frequency driver. The LFT-VIII minimum recommended amplifier is 50 watts/channel and the maximum is 200 watts/channel. The speaker is moderately efficient; its impedance averages 8 ohms.
The low frequency woofer was designed to blend seamlessly with the mid-range and high-frequency drivers. The design uses a very low crossover frequency (180 Hz) between woofer and midrange. The woofer has a very high compliance and operates with a near critically-damped system Q of .58 to insure excellent transient response.
The panels are attached to a rigid steel frame to prevent resonances, and the woofer is mounted in a rigidly braced enclosure. The LFT-VIII is bi-ampable and uses the Edison Price Music Post. The standard finish is oak with black grills (shown), optional finishes are available for an additional charge.
Selling at RM8,800.00 only. Call at 012-3282993.
advance audiophile
Number of posts : 602
