Bel Canto Design Celio Power Amplifier (used)
2 posters
Bel Canto Design Balanced Single-ended Audio Power Amplifier.
The Celio is a dual configuration, stereo/mono power audio amplifier using a unique Bel Canto Design, Balanced Single-ended circuit architecture. This design combines the musicality of the single-ended triode amplifier with higher power and versatility of a FET based design.
Condition: 8/10
Price : MYR 4,300.00
Contact: Wong @ +60122117506
[img]https://www.hifi4sale.net/[/img]
Power output per channel into 2, 4 or 8 ohms • 50 watts Class A/AB
• up to 170 watts Class AB Mono
Bandwidth -3dB • 2Hz-30KHz
Input level for full watts output • 1 Volt rms on balanced input
Signal to Noise Ratio re 1 watt out • >96 dB A weighted
Distortion at 10 watt 1kHz • <0.1% low order harmonic
Damping Factor • >10 across full bandwidth
Input configuration and impedance • single-ended/balanced 100Kohm
Gain at 8 ohm tap • 25 dB with balanced input
Power Requirements • 100-120 VAC 50-60 Hz or 220-240 VAC 50-60 Hz
• 300 Watts
Size • 17.5" W x 16" D x 6.5" H (445 mm x 407 mm x 165 mm)
Weight • 65 lbs (29.25 kg)
• 300 Watts
Condition: 8/10
whwong- Regular
- Number of posts : 67
Registration date : 2010-07-14
whwong- Regular
whwong- Regular
Bel Canto Celio Power Amplifier
You have any confidence that the Amp will be able to drive my Apogee Duetta Signature? My BAT VK500 just blow all the output transistores. Price negotiable? Thanks Rabtah
fireballmivec6315- Frequent Contributor
- Number of posts : 285
Registration date : 2012-02-24
Re: Bel Canto Design Celio Power Amplifier (used)
Hi Rabtah,
You've got PM.
You've got PM.
whwong- Regular
» Bel Canto Designs Celio power amp (Used)
» Bel canto design orfeo 60 monoblock power amp (Used)SOLD
» Bel Canto eVo2 Gen II Power Amplifier (Used)SOLD
» SOLD-Bel Canto S 300 stereo power amplifier
» Bel Canto M300 Monoblocks Power Amplifier - 1 pair (Used)
