Calling Roksan TT owner...need help
4 posters
I'm looking for Roksan protractor alignment template. Anyone that kind enough to lend, photostat would very much appreciated...thanks.
pm me..
pm me..
Re: Calling Roksan TT owner...need help
Have you tried www.vinylengine.com? They have lots of resources for all makes of turntables.
Rajacatur- Club Member
- Number of posts : 42
Source(s): Linn Sondek LP12/Cirkus/Ittok LVII/Benz Glider SL/Armadeddon/Naim CD5i-2
Amplification: Pipit 22L/NAC72/Hicap/NAP250
Speakers: Proac Response D18
Assuming you have a Roksan Radius t/table. The attached should help :=
http://www.roksan.co.uk/roksan/products/no_33/doc/d_33_4.pdf
However should you have the Tabriz or Artemiz tonearm instead of the Nima tonearm, it applies. Should take the time to surf the web though IMO
- Number of posts : 137
Amplification: Nuprime STA-9
Speakers: B&W 706 /AVI DM 10
Apologies, did not realize that the guide did not provide the template. Need to research further. The issue here is that Roksan tonearm has an effective length of 240mm and not the 'Rega' standard of 237mm and probably uses the Pro-ject tonearm template instead. Check the Pro-ject website instead.
If you do not mind non standard protractors, try this : =
http://mkjnovak.homestead.com/music.html it works on a principle by pointing to the pivot and is similar to the Avid t/table protractor. Avid produce some mighty expensive t/tables and if it s good for them, well....
Thanks all, I've tried Vinyl engine but to no avail. Roksan has 222.5 spindle ti pivot and 240mm effective length...Samazzah, thanks for your help.
Try using a universal alignment tool like the Clearaudio gauge. It can align from between 200mm to 330mm pivot-spindle distances and with a choice of 4 different alignment settings depending on what innermost groove you would like to optimize for your setup.
Dwango- Dealer\Reseller\Trader\Service Provider
- Number of posts : 10
Registration date : 2011-08-07
» calling all marantz owner!!
» Von Schweikert owner thread
» Lenco L75 owner (v-block)
» Roksan TMS3 Turntable With Roksan Caspian Power Supply
» any owner of proceed pav av amp
