crackly sound from sliding level control ( sound mixer )
Post by song on Fri Feb 03, 2012 12:54 pm
Dear all,
Some has reported that WD40 is not to be used to clear away the crackly sound from level control. Can anyone advise where to obtain Deoxit or similar product in Malaysia.
Thank you.
song
Male Number of posts: 2
Registration date: 2009-03-10
Re: crackly sound from sliding level control ( sound mixer )
Post by cmboy on Fri Feb 03, 2012 1:24 pm
Generally, WD40 isn't designed for servicing electronic, audio or related equipment, especially spraying into volume controls, selector switches or electro mechanical devices. WD 40 is suited for household fixes and mechanical industry.
Technicians usually use a contact switch cleaner which can be obtained from well stocked electronic supply shops. These products are designed for servicing electrical switches and contact devices. But then again, it can only do so much and not remedy devices that are seriously worn or internally defective.
Electronic shops at Jalan Pasar Kuala Lumpur do sell canned sprays for electronic servicing. I think some well stocked shop in other cities may have some.
Some brands seen here from CRC, Philips and Kontakt. These have been around quite a while.
http://www.kontaktchemie.dk/Produktoversigt/kontakt_60.htm
cmboy
Male Number of posts: 1163
Registration date: 2009-03-11
Post by adrian4454 on Fri Feb 03, 2012 2:01 pm
wah kawan song, liau la; the WD40 going to smoke your mixer man if it ever touches any high current circuit.
Go with what cmboy suggest~
adrian4454
Male Number of posts: 425
Registration date: 2009-02-03
Post by song on Mon Feb 06, 2012 1:59 pm
Dont worry, I didnt use WD40. I am a careful audio fan.
Thanks to a kind friend who gave me the mixer that need minor maintenance. Its now working good.
Thank you for the kind advice.
song
