Synthesis Metropolis NYS-100i Monster Integrated Amplifier from Italy
SYNTHESIS-ART OF SOUND
2 Models available:METROPOLIS NYS 100i & NYS-175I MONSTER Integrated Valve Amplifiers
NEW INTRO PRICE NYS-100i@ $22000.00/each.
Free Audioplus Polyphony-1 10 ga PCOCC+ Speaker Cable valued@ $3999.00/2.5m pair with every purchased.
MODEL: METROPOLIS NYS-100i INTEGRATED AMPLIFIER
SYNTHESIS is proud to introduce a stereo tube amplifier incorporating the exceptional the sonic performance. The NYC 100i provides a minimum of 200 watts (100 wpc), power output from 8, KT-66's in Ultra Linear (UL) - push/pull operation. The NYC 100i features a newly designed custom output transformer designed to achieve highly delicate and precise sound with extraordinary musicality from tubes, but with the authority of the best transistor amplifier. - Aluminium Knobs Two 45mm CNC machined control knobs with integral soft light and laser etched indication segments. - DC Powered tube heater All tubes, except KT66, have DC stabilised heater circuits to reduce hum noise to a near in-audible minimum. - Output transformer The Output transformer uses a double C-core Hi-Grade Iron-Silicon for superb frequency reproduction and bandwidth. With this newly designed custom output transformer unique to the NYC100i we are able to achieving highly delicate and precise sound reproduction faithful to the original recording. - Mechanical chassis construction The power supply and output transformers are held by an extremely rigid “H” structure that keeps the unit free from unwanted vibrations which further helps reduce unwanted noise to the tubes. - Remote control A superb wooden handmade case with soft button design, perfectly matching the aesthetics for the “Metropolis” series. - Feet Four CNC machined aluminium feet with an insert of natural rubber. The depth and form of these rubber feet is calculated to minimize the vibration of the amplifier in isolation from its surroundings. - Fan A 120mm fan provides a speed between 500 to 700 rpm which is controlled via the supplied adapter. This ULN (Ultra-Low-Noise) unit is tailor made for the serious enthusiast who demands super-slow running speeds and the utmost silence of operation. - Bias control The factory set fine bias control is microprocessor controlled to maintain the optimum settings. If required this can be adjusted without the use of an external voltmeter by use of an internally fitted display device. - Dual mono Circuitry A completely dual mono design minimises the crosstalk across channels. Power transformers use hi-grade iron silicon M0 and separate supplies with hi-grade selected capacitors to produce extremely low ripple levels. The screen grids have a completely separate and stabilised supply for extended signal to noise ratio against external voltage noise and variations. - Mechanical chassis construction The power supply and output transformers are held by an extremely rigid “H” structure that keeps the unit free from unwanted vibrations which further helps reduce unwanted noise to the tubes. - Remote control A superb wooden handmade case with soft button design, perfectly matching the aesthetics for the “Metropolis” series. - Feet Four CNC machined aluminium feet with an insert of natural rubber. The depth and form of these rubber feet is calculated to minimize the vibration of the amplifier in isolation from its surroundings. - Binding posts Gold plated professional binding posts for a continued oxidisation free connection further improve sound refinement. - Components Components for the NYC 100i have been selected with great care throughout. Only the best available components are considered and all must undergo an exhaustive analysis of their sonic influence prior to final selection. - Selected tubes All tubes used are selected after 2 stage warm up. A fully computer monitored machine controls the process and at the end of this, selects the perfect tubes which are matched for a perfect balance.
Technical specifications:
NYC 100i Power stage (1 ch.):
4 X KT66 Driver (1 ch.):
12BH7 Input stage (1 ch.):
ECC83/12AX7 Controls: Front: Power switch, input switch selector, volume. Rear:, RCA gold plated connectors, power connectors , power plug, XLR connctors, fan, Binding post. Inputs: DAC, TUNER, DVD CDP, XLR.
Outputs: PRE OUT
Frequency response: 20Hz to 20KHz +- 0.5dB
Input impedance:
Input sensitivity: Output impedance: Power stage configuration: Power output: Signal/Noise ratio: Finish: Power consumption:: Dimensions: (w,d,h) Weight: 50Kohm 200mV / 100W 4 - 8 ohm Ultralinear 43% tap 100W RMS into 4/8 ohm each channel AB1 Class >85dB, A weighted Aluminium and piano black laquer lateral panel 300W 450x630x260mm 50.0 Kg
Audition now @
Musiclink AV Distribution
100 Beach Road, #02-47
Shaw Tower, Singapore 189702
Tel:62911106
Mon-Sat:12.30-8pm daily
Sun:CLOSED
Closed on all holidays
musiclinkav- Dealer\Reseller\Trader\Service Provider
- Number of posts : 209
» Synthesis Metropolis NYS-175i Monster Integrated Amplifier from Italy
» Synthesis Hybrid CD + Integrated Amplifier from Italy
» Synthesis Nimis integrated amplifier (used)
» Synthesis Hybrid Tubed CDP & Integrated Amplifier from Italy
» Synthesis Isobel Solid State Integrated amplifier made in Italy
