KR Audio
KR Audio
KR Audio P130 Stereo Pre Amplifier
Retail Price: SGD$5500.00
Description: Unity gain pre-amplifier with phono stage
Output Tubes: 2 x KR 5
Bandwidth: 10 Hz-100kHz (-3dB)
Output Impedance: 2k Ohms
Input: 1V RMS / 47 kOhms
Dimensions - w x h x d:36.5 x 8.5 x 26 cm
Weight: Approx. 6.5 kg
Review:
http://www.highend-electronics.com/newsletter13/he-newsletter13.html
http://www.enjoythemusic.com/ces_2011/preview/page2.htm
https://www.facebook.com/home.php#!/pages/KR-TUBE-AUDIO/113192315379581
KR Audio Kronzilla DXMKII
Retail Price: SGD$40000.00
Description: Single-ended tube amplifier - pure class A, zero feedback, Pure star Power and Ground Architectures, Ultra Fast Power Supply
Output Tubes: 4 x T1610 ( parallel pair per mono-block )
Output Power: 2 x 100 Watts RMS (THD=1%)
Bandwidth: 20 Hz-22 kHz (-3dB)
Output Impedance: 4 / 8 Ohms
Input: 1V RMS / 47 kOhms at 100 W
Dimensions - w x h x d:38.5 x 41.5 x 55 cm (one ch.)
Weight: Approx. 37kg (one ch.)
Review:
http://www.ultrahighendforum.com/viewtopic.php?f=199&t=4030&view=previous
http://www.audiophilia.com/hardware/kronzilla.htm
http://www.stereophile.com/content/mighty-kronzilla
http://www.highend-electronics.com/kr_audio.html
KR Audio Kronzilla SXI Mk II A StereoMojo Exclusive World’s First Review
Retail Price: SGD$23,000.00
Description: Single-ended tube amplifier - pure class A,Pure star power and ground architectures, zero feedback
Output Tubes: 2 x T1610
Output Power: 2 x 50 Watts RMS (THD=2%)
Bandwidth: 20 Hz-20 kHz (-3dB)
Output Impedance: 4, 8 Ohms
Input: 4 x 0.75V RMS / 47 kOhms at 50 W
Dimensions (w/h/d): 38.5 x 41.5 x 55 cm
Weight: Approx. 47kg
Review:
http://www.avhub.com.au/index.php/Features/Hi-Fi/kr-audio-a-factory-tour/All-Pages.html
http://www.stereomojo.com/KR%20Audio%20Kronzilla%20SX1%20Mk%20II%20Review/KRAudioKronzillaSX1MkIIAmplifierReview.htm
http://www.audiocircle.com/index.php?topic=78724.0
http://forum.audiogon.com/cgi-bin/fr_memb.pl?0&1&listflup&zzHchilcoat
KR Audio VA-300I Antares
Retail Price: SGD$8000.00
https://www.facebook.com/photo.php?fbid=244276972271114&set=a.114737605225052.11481.113192315379581&type=1&ref=nf
Technical Data Power Tubes 2 x KR300B Output Power 2 x 12 WRMS (THD=3%) Output Impedance 4, 8 W Frequency Response 20Hz ¸20KHz (-3dB) Feedback zero Damping Factor Approx. 2.6 Preamplifier passive with mechanical (reed)relays Remote Control volume & channel selector Inputs 4 x line RCA (Cinch) Input Sensitivity 1VRMS / 47kW ( at 12 W ) Power requirements 230/115VAC , 50/60 Hz Power consumption 140VA Operating temperature 5C° to 40C° Weight Approx. 38Kg Dimensions including projecting parts and controls (w/h/d) Approx. 38.5 x 25.5 x 55 cm
KR Audio VA 340
Retail Price: SGD$10,000
Review:
http://www.6moons.com/audioreviews/kraudio3/va340.html
http://www.kraudiousa.com/product-reviews.php
http://www.audiophilia.com/hardware/kraudio.htm
http://www.kraudioproducts.com/Kr/ProductDetail.aspx?CatID=14&ProductID=10
http://www.enjoythemusic.com/superioraudio/equipment/1205/kraudiova340.htm
http://www.sonicflare.com/archives/kr-audio-va340-review.php
http://www.soundclub.pl/urzadzenia/VA_340/112.html/
KR Audio VA 350i
REtail Price: SGD$12000.00
Review:
http://www.6moons.com/audioreviews/kraudio5/350i.html
KR Audio VA 350i Amplifier 2 x 30 watts Class A No negative Feedback Single-ended triode
This stage could consistently implement its technology KR Audio. With the newly designed tube amplifier T 100 could be developed here, one of the limitations of the old times and structures could not shake.
The tube T 100 is a triode designed as a complete redesign. Recognized worldwide, the sound quality of previous Leistungtrioden. And even though the applied models such as 845 or 211 are actually Sendetrioden that were not designed for music playback. How, then, must be a tube amp sound its heart rather than wireless systems, consistently low music player is designed for. We assure you - simply thrilling. Musically, with attack, dynamic and full of fine details.
The exception in this tube is enormous effort has been involved in a squeaky clean working power supply to the JFET driver stages here is a technological fireworks offered. Here LR is the technology of the legendary Kronzilla audio formats offered in a downsized. The design of the VA by 350 while its own individual language.
This amplifier is a legend of tomorrow. Able to drive even the most complex speaker, he offers the full sonic potential of the entire KR Audio technology.
Features
Class A stereo power amplifier
Single-ended triode
No negative feedback
XLR input as option
Technical data
Property Value
Power Tubes 2 x T100
Output Power 2 x 30 WRMS
Output Impedence 20Hz-20KHz (-3db)
Feedback 0
Damping Factor about 2.8
Sensitivity 0.75VRMS/47Kohms @30W
Power Supply 230/115 VAC, 50/60 Hz
Power comsumption 300VA
Operating Temperature 5 ° C to 40 ° C
Weight approx 37Kg
Dimension 5.3.5 x 30.5 x 41.5 cm
KR Audio VA 880
Specifications:
Power Tubes: 4x KT88
Output stage Push-Pull Ultra-linear Class AB1
Output Power 2 x 60 WRMS(THD=1%)
Output Impedance 4 W Frequency Response 20 Hz , 20 KHz(-1dB)
Feedback 7 dB
Drive stage MOSFET class A
Preamplifier solid- state with mechanical (reed) relays
Inputs 4 x line RCA
Video: https://www.youtube.com/watch?v=lcPf5XTUPJ4
Review:
http://www.6moons.com/industryfeatures/rotterdam09/3.html
http://www.audiocircle.com/index.php?action=gallery;sa=album;id=2502
http://www.qualityhifi.nl/Februari_2009/KR_Audio_Electronics_viert_15_jarig_bestaan_met_de_VA_880.html
KR Audio VA885
Retail Price: SGD$9000.00
Review:
http://en.audioreview.nl/nieuws/207-twee-wereld-primeurs-van-kr-audio-electronics
KR Audio 845
Specifications:
http://www.kraudio.com/index.php?option=com_content&view=article&id=46%3A845&catid=4&Itemid=7&lang=en
KR Audio 300B
Retail Price: SGD$950.00
KR Audio 211
Specifications:
http://www.kraudio.com/index.php?option=com_content&view=article&id=45%3A211&catid=4&Itemid=7&lang=en
KR Audio 842VHD
Specifications:
http://www.kraudio.com/index.php?option=com_content&view=article&id=43%3A842vhd&catid=4&Itemid=7&lang=en
http://audioline-hifi.com/
TKS FOR VIEWING…… CHEERS…..
Interested Parties can view at Block 925 Yishun Central 1 #02-229 Singapore.
Or you can reach me at +65 67565 585 during operating hours.
Will sent oversea using only FEDEX.
Sunday & Monday 1200 HRS to 1700 HRS
Tuesday to Saturday 1200 HRS to 1800 HRS
Review:
Review:
Review:
KR Audio VA 340
Review:
KR Audio VA 350i
Review:
Features
Single-ended triode
XLR input as option
Technical data
Property Value
Feedback 0
Weight approx 37Kg
KR Audio VA 880
Specifications:
Feedback 7 dB
Inputs 4 x line RCA
Review:
KR Audio VA885
Review:
KR Audio 845
Specifications:
KR Audio 300B
KR Audio 211
Specifications:
KR Audio 842VHD
Specifications:
Re: KR Audio
Item will be on demo at the below mention address and dates.
Raffles City Convention Centre
Address: 80 Bras Basah Road. Singapore 189560
Room: FULLERTON
Date: 17/08/2013 – 18/08/2013
Room: FULLERTON
» Upscale audio precision selected 6H30 preamp tube Audio research & many
» cambrigde audio DAC 3 & cambrige audio disc magic 1 transport sale (used)
» Cambridge Audio CXN (V2) Series 1 Network Audio Streamer Player (Used) SOLD
» JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit
» WTB: Tube amplifier - Cary Audio, Rogue Audio, PrimaLuna & Jadis
