JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit Empty JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit
Post by raymond88 Tue Jun 09, 2020 2:58 pm
Item: JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit
Condition: New. Last 2 sets
Price: RM1299 or swap/topup
Click here to Whatsapp:
http://wasap.my/60123816611
JL Audio JLink TRX Wireless Kit
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit Jl1110
Unleash your sub or other audio gear with this wireless kit
JL Audio's JLINK TRX Wireless, High-Fidelity Audio Transmitter & Receiver Kit adds wireless capability to a powered subwoofer in seconds. Simply connect the JLINK transmitter to your home theater receiver's subwoofer output. Then plug the JLINK's receiver module into your sub. The kit's 100-foot wireless range gives you the freedom to place your sub anywhere you like without the need to run long interconnect cables across your floor. Plus, the transmitter and receiver modules' compact size make them easy to hide.
The JLINK TRX isn't just limited to subwoofers. It can be used to wirelessly connect any two line-level audio devices together. For example, you can send crystal-clear, full-range stereo sound from a source component like a CD player to your receiver or a pair of powered speakers across the room, or throughout your home. Each transmitter can support up to four receivers (additional receivers sold separately). Think of the possibilities. Each kit comes with AC power supplies for the transmitter and receiver. And if you have a JLINK compatible JL Audio subwoofer, you can use its built-in JLINK port to make a handy single-wire power and audio connection to the receiver using the supplied JLINK cable.
[size=13]READ LESS
[/size]
Product highlights:
  • includes wireless transmitter and receiver for use with powered subwoofers
  • compatible with any brand of subwoofer or other audio gear with mono or stereo RCA connections
  • 16-22,000 Hz frequency response for outstanding fidelity in subwoofer and full-range applications
  • 16-bit/48 kHz bit-perfect digital PCM stereo wireless technology
  • wireless range: up to 100 feet
  • operates on 2.4GHz wireless band
  • receiver includes JLink port and cable for use with compatible JL Audio products
What's in the box:
JL Audio JLINK:tm: TRX High-Fidelity Audio Transmitter & Receiver Kit owner's manual
  • Wireless transmitter
  • Wireless receiver
  • 2 AC power adapters (w/ attached 59" DC cords)
  • 39" JLINK cable
  • 2 Hook-and-Loop fasteners
  • User Manual
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit J11010
https://www.youtube.com/watch?v=_X6JpXeoyXg
https://www.jlaudio.com/products/jlink-trx-home-audio-wireless-kit-96102
https://www.crutchfield.com/S-xN2s7fj4esI/p_136TRX/JL-Audio-JLINK-TRX-High-Fidelity-Audio-Transmitter-Receiver-Kit.html
https://www.paragonsns.com/products/jl-audio-jlink-trx
Number of posts : 10041
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit Empty Re: JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit
Post by raymond88 Wed Jun 17, 2020 10:49 am
Post by raymond88 Thu Jun 25, 2020 9:51 am
Post by raymond88 Thu Jun 25, 2020 9:52 am
Post by raymond88 Fri Jul 03, 2020 5:14 pm
Post by raymond88 Mon Jul 13, 2020 1:17 pm
Post by raymond88 Tue Jul 21, 2020 10:55 am
Post by raymond88 Wed Jul 29, 2020 4:12 pm
