HiFaceTWO (USB to SPDIF Converter) by M2TECH New.
2 posters
The M2TECH HIFACE TWO
*Excellent To Connect Your PC/MAC to older DACs not having USB Inputs.
*Great for DACS which does not have Asynchronous Example, Rega DAC etc.
*Superb for Budget DACS which has poor internal clock implementation.
*King of Budget Audiophile! Squeeze the Last bit Performance from your DAC.
Highest quality digital audio up to 192kHz/24bit S/PDIF audio format available from your PC, MAC or Linux computer. Very low jitter oscillators, asynchronous transfer on USB.
What Is this Anwyay? If you own a DAC (Digital To Analog Converter) the signal which is delivered from your computer to your DAC via USB s loaded with erosive jitter signal which deters the signal and ultimately the sound we hear, by adding the HiFace Two you almost completely eliminates this issue and the output
is extremely organic like a good priced high end cd player, but just out of your PC or MAC.
Full 360 Degrees View
Ever wondered why your top-dollar DAC never sounded as good as your modest Cd Player, Here in lies the Answer "The Hiface TWO"
Compact (2x2.2x10.2cm) with hi-end performances hiFace Two USB interface has been conceived to further improve the performance and ease of use of the acclaimed and award-winning hiFace. hiFace Two input format is a data stream signal with sampling frequency/resolution up to 192kHz/24bits, compliant to USB Audio 2.0 specificastions, available from a PC, MAC or Linux computer USB port. A very high quality S/PDIF stereo audio output signal is available from hiFace for your Hi-Fi system DAC (Digital to Analog Converter). HiFace looks like a small USB pendrive, featuring a very compact size. Internal very low jitter oscillators allow for playing 192kHz/24bits audio files that feature the best signal quality. hiFace Two is even easier to use than the hiFace. No drivers are necessary with either Mac and Linux computers, while a single standard driver is required for Windows computers. While the old hiFace offered Direct Sound, Kernel Streaming and WASAPI transfer modes, hiFace Two adds ASIO mode to enable interfacing to pro players and software tools. hiFace improves the audio performance over the hiFace by a new output circuit compliant with S/PDIF levels, linear regulators in place of switching ones and a clickless operation even when skipping tracks.
How It's Done?
FEATURES
1)LOW JITTER, LOW PHASE NOISE, HIGH STABILITY OSCILLATORS Most audio interfaces and USB-provided DACs refer the data stream clock to the same USB interface clock, that often suffers a very heavy jitter (short range oscillator frequency variations). Thanks to two quartz precision oscillators used on M2Tech hiFace, clock source for output data stream features a very low jitter. A more stable clock is recovered by DAC S/PDIF receiver; a low jitter produces a very limited sound image distortion and degradation. Phase noise (main responsible for jitter) is also very low: this guarantees a short and long range clock stability, also reinforced by a board supply voltage regulation (e.g. at environmental temperature stability is 2-5ppm approximately, compared to 50-100ppm performed by oscillators normally used on commercial CD players).
2)USB 2.0 AUDIO COMPLIANCE NCE no more needs for custom driver. Using the hiFace Two is very easy. Just connect it to your Mac or Linux computer and it will be immediately visible in the devices list and ready to use. A driver is still necessary for Windows computers, which enables for DS, KS, WASAPI and ASIO mode.
3)COMPACT SIZE AND EASE OF USE M2Tech hiFace features a very compact size and can be directly (or using an accessory USB A-A adapter, not supplied with hiFace) connected to a High Speed USB 2.0 port of any computer. A very high electric and mechanical performance RCA gold connector provides an output signal, ready to be connected to a Hi-End system. No external power supply is required, as hiFace draws its power from USB bus itself and regulates it with its internal regulators. hiFace USB interface connected to a last generation mini PC provided with a High Speed USB port makes for a complete music transport system at very low prices (in the range of few hundreds Euros). Such system allows for listening any density and resolution music files, playing own CD's using a CD ROM drive, obtaining access to more than 10,000 web radio, many of which broadcast their transmissions with CD quality.
Internal Construction
Works wonderfully with almost all USB DACs / NON-USB DACs (Ex.Schitt Bifrost DAC) and A/V Receivers (with Built in DAC) to transport music
mellifluously and melodiously to greater effect.Works Well with few models of Rega DACs (which does not have asynchronous USB, adding the Hiface TWO
brings a definite sonic improvement).
RCA Version STANDARD
PRICE RM 623.00 Warranted for 1 Year (Updated May 1st 2014)
BNC Version (Available Upon Request)
RM 623.00 Warranted for 1 Year(Updated May 1st 2014)
100% Made in Italy
Available ONLY at Authorized Dealers Below :
Kuala Lumpur / Selangor
Acoustique Systems
Amcorp Mall
Mr.C.N.LIM (H/P : 012-3393738)
BEWARE OF PIRATED MADE IN CHINA CLONES THATS PRICED THE SAME,
LOOKS THE SAME, BUT DOES NOT SOUND THE SAME, MADE IN CHINA NEVER
EQUALS TO THE HIGH END FINISH OF EUROPEAN MANUFACTURING.
How It's Done?
FEATURES
100% Made in Italy
Acoustique Systems
Amcorp Mall
quintaruban- Dealer\Reseller\Trader\Service Provider
- Number of posts : 242
Registration date : 2011-02-20
Re: HiFaceTWO (USB to SPDIF Converter) by M2TECH New.
Back in Stock
Video of HiFace 1 (Diapason Award Winner)
Price Updated - 2013 Prices Cheaper by 10.00 Ringgit from Global RRP! In stock in 7 days.
This is a great product - using it from my Mac Air to my Schiit Bifrost DAC - great sound and helps with Macs/laptops which have issues with the USB ports providing insufficient power output.
Recommended!
Recommended!
CH Liew- Frequent Contributor
- Number of posts : 255
Registration date : 2011-07-04
CH Liew wrote:This is a great product - using it from my Mac Air to my Schiit Bifrost DAC - great sound and helps with Macs/laptops which have issues with the USB ports providing insufficient power output.
Recommended!
Thank you for your support CH Liew!
bump only few left.
bump last piece!
bump last 2 piece.
» M2Tech hiFace Two USB to SPDIF Converter
» M2TECH HiFaceEvo (Made in Italy USB to SPDIF Converter) New!
» M2Tech hiFace 24/192 Async USB-SPDIF converter (NEW)
» M2Tech HiFace ONE (USB to SPDIF Interface Made in Italy) NEW!
