M2Tech HiFace ONE (USB to SPDIF Interface Made in Italy) NEW!
M2TECH HIFACE D/D CONVERTER
2013 Update
*hiFace and hiFace Evo, when operated in Kernel Streaming mode or any other bit-perfect mode, can deliver DoP (DSD over PCM) to any DSD DAC through their outputs. This is very interesting to every owner of a DAC capable of decoding DSD transferred to its S/PDIF or AES/EBU input.
What is it?
HIFACE is a Digital to Digital Converter, which converters jitter induced digital signal from your computer (PC/MAC) to a cleaner, more music/sound
friendly digital format which is SPDIF (developed by Sony and Philips and has become a gold standard in transmitting high quality digital signal across
the board between various interfaces and platforms) into your Digital to Analog Converter or DAC.
What is it for?
For 1.Better/Cleaner Quality of Sound 2.Improved Timing 3.Darker Background
4.If you have an older Digital to Analog Converter or DAC which does not have Asynchronous Conversion, this does the trick.
5.If you are unhappy with the sound of your DAC which induces echo to vocals and, poor bass or weak treble.
YouTube Video
DETAILS
Highest quality digital audio up to 192kHz/24bit S/PDIF audio format available from your PC or MAC Very low jitter oscillators and proprietary drivers Compact size (2x2.2x10.2cm) with hi-end performances hiFace USB interface has been conceived to obtain the highest quality digital audio signal using a PC or MAC. hiFace input format is a data stream signal with sampling frequency/resolution up to 192kHz/24bits, available from a PC or MAC USB port. A very high quality S/PDIF stereo audio output signal is available from hiFace for your Hi-Fi system DAC (Digital to Analog Converter). HiFace looks like a small USB pendrive, featuring a very compact size. Internal very low jitter oscillators and proprietary drivers allow for playing 192kHz/24bits audio files that feature the best signal quality.
FEATURES
1) LOW JITTER, LOW PHASE NOISE, HIGH STABILITY OSCILLATORS
Most audio interfaces and USB-provided DACs refer the data stream clock to the same USB interface clock, that often suffers a very heavy jitter
(short range oscillator frequency variations). Thanks to two quartz precision oscillators used on M2Tech hiFace, clock source for output data stream
features a very low jitter. A more stable clock is recovered by DAC S/PDIF receiver; a low jitter produces a very limited sound image distortion and degradation.Phase noise (main responsible for jitter) is also very low: this guarantees a short and long range clock stability, also reinforced by a board
supply voltage regulation e.g. at environmental temperature stability is 2-5ppm approximately compared to 50-100ppm performed by oscillators
normally used on commercial CD players).
2) PROPRIETARY DRIVERS
The standard audio drivers available on the market (e.g. Microsoft Windows operating system) dictated constraints can be overcome thanks to hiFace proprietary drivers: they allow for transferring audio data, maintaining the original file quality without any loss of resolution quality; also, sampling frequency constraints are overcome, while Microsoft and ASIO drivers oblige to operate at no more than 96kHz. When hiFace is used together with a player application such as FooBar (available for free on Internet), you can transfer S/PDIF stream music files to a D/A converter at 192kHz/24bits maximum frequency/resolution, avoiding undesired PC or MAC audio mixer data processing during the data transfer from hard disk to interface. Presently, Windows XP, Vista, Windows 7 drivers are available, as well as Mac drivers for 10.4, 10.5 and 10.6.
3) COMPACT SIZE AND EASE OF USE
M2Tech hiFace features a very compact size and can be directly (or using an accessory USB A-A adapter, not supplied with hiFace) connected to a High Speed USB 2.0 port of any computer. A very high electric and mechanical performance RCA gold connector provides an output signal, ready to be connected to a Hi-End system. No external power supply is required, as hiFace draws its power from USB bus itself and regulates it with its internal regulators. hiFace USB interface connected to a last generation mini PC provided with a High Speed USB port makes for a complete music transport system at very low prices (in the range of few hundreds Euros). Such system allows for listening any density and resolution music files, playing own CD's using a CD ROM drive, obtaining access to more than 10,000 web radio, many of which broadcast their transmissions with CD quality.
Internal Construction of the HiFace One
SPECIFICATIONS
Connections
Input 1 x USB A type male
Output 1 x RCA female
I/O Standard
Input USB 2.0 Format
Output S/PDIF Stereo Digital Audio Format
Sampling Frequency
44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4khZ, 192kHz
Resolution 16 up to 24 bit
Dimensions 10.2(d) x 2.2(h) x 2(w) cm
Power Supply 5V DC from USB bus
Temperature from 0°C to 70°C
Weight 50gr approx.
Made in Italy
Price : RM 425.00
Available ONLY at Authorized Dealers Below :
Kuala Lumpur / Selangor
Acoustique Systems
Amcorp Mall
Mr.C.N.LIM (H/P : 012-3393738)
*Penang
(February 2012 ,
New Retailer is in the midst of re-appointment or if you are a Retailer please
contact us at ganesh[at]tridentmalaysia[dot]com if you are current owner
of any M2TECH product in Penang and need support please do not hesitate to
email us)
For Other States and Product and Dealer Enquiries please contact
Mr.Ganesh at ganesh[at]tridentmalaysia[dot]com
2013 Update
What is it?
What is it for?
YouTube Video
DETAILS
FEATURES
SPECIFICATIONS
Connections
I/O Standard
Sampling Frequency
Weight 50gr approx.
Made in Italy
Price : RM 425.00
Acoustique Systems
Amcorp Mall
*Penang
(February 2012 ,
email us)
quintaruban- Dealer\Reseller\Trader\Service Provider
- Number of posts : 242
Registration date : 2011-02-20
Re: M2Tech HiFace ONE (USB to SPDIF Interface Made in Italy) NEW!
» M2Tech HiFace 24/192 USB/SPDIF Interface (USED)SOLD
» HiFace® "PocketDAC" by M2TECH 32 bit/384 Khz DAC (New - Made in Italy)
» M2TECH HiFaceEvo (Made in Italy USB to SPDIF Converter) New!
» M2Tech hiFace Evo (USB 24/192 Interface for DAC) (NEW)
» M2Tech hiFace Two USB to SPDIF Converter
