HiFace® "PocketDAC" by M2TECH 32 bit/384 Khz DAC (New - Made in Italy)
Presenting the most awaited release of 2013 - Your quintessential 'In Your Pocket' Digital to Analog Converter, which is not only affordable but delivers unsurpassed performance given its price range.
First of it's kind the HiFace®DAC is the first true 32 bit 384 Khz Digital to Analog converter which plays both native and up sampled material via Apple (Macbook/IMAC/IPAD/MacMini) or Windows platform.
Ideal for listeners across the board ranging from travelers, to advanced audiophiles or newcomers to the digital to analog playback chain this device offers a dynamic but grounded sound which ensures good conversion for all types of music.
Simply plug the HiFace®DAC into your computer, iPad or
(any Tablet running on the latest Android Platfom) to turn your device
to a high end music playback device.
Long gone are the days of boomy and cluttered sound out of your computer, with just an added addition of a Minijack to Stereo Cable or Minijack to Stereo Adaptor (to be purchased separately).
Now you can connect your computer to any HiFi System or Active Speakers.
One may even connect it to your IPAD or Tablet (with Android Platform) to connect your Car's Hifi Sytem if one's car should be equipped with an Auxillary Input (Aux)
with the additional use of Minijack-to-Minijack Cable (to be purchased seperately).
The HiFace®DAC is not just a missing link between your computer and your system, but a true high end device capable of unfolding stellar details from your high resolutions files.
Now hear the music at will at almost 4 times the resolution of CD!
If you have a high impedance headphone, the HiFace®DAC will also do the job that of an headphone amplifier! With Internet Radios playing back higher resolution over the web,now you are able to transmit this to your HiFi System with the same clarity it is intended.
with iPad
with Samsung S3 (Courtesy of AudioSoul Ltd)
All this and Truly Made in Italy!
HiFace®DAC is the Highest quality stereo analog audio up to 384kHz/32bit available on your PC, Mac, Linux computer, iPad or Android tablet.
2.0Vrms line output level, 112dB THD+N.
Very low jitter oscillators, asynchronous 2.0 Audio Class USB.
Also drives most medium- or high-impedance headphones.
Highest value-for-money.
FEATURES
1)LOW JITTER, LOW PHASE NOISE, HIGH STABILITY OSCILLATORS Most audio interfaces and USB-provided DACs refer the data stream clock to the same USB interface clock, that often suffers a very heavy jitter (short range oscillator frequency variations). Thanks to two quartz precision oscillators used on M2Tech hiFace DAC, clock source for internal interface to the conversion IC features a very low jitter. Low jitter produces a very limited sound image distortion and degradation. Phase noise (main responsible for jitter) is also very low: this guarantees a short and long range clock stability, also reinforced by a board supply voltage regulation (e.g. at environmental temperature stability is 2-5ppm approximately, compared to 50-100ppm performed by oscillators normally used on commercial CD players).
2)USB 2.0 AUDIO COMPLIANCE No need for custom driver. Using the hiFace DAC is very easy. Just connect it to your Mac, iPad or Linux computer and it will be immediately visible in the devices list and ready to use. A driver is still necessary for Windows computers, which enables for DS, KS, WASAPI and ASIO mode.
3)COMPACT SIZE, EASE OF USE AND VERY HIGH PERFORMANCE M2Tech hiFace DAC features a very compact size and can be directly (or using an accessory USB A-A adapter, not supplied with hiFace) connected to a High Speed USB 2.0 port of any computer or tablet. A 3.5mm stereo jack socket provides an output stereo line-level signal, ready to be connected to a Hi-End system. No external power supply is required, as hiFace DAC draws its power from USB bus itself and regulates it with its internal regulators. hiFace DAC connected to a last generation mini PC provided with a High Speed USB port makes for a complete digital music source at very low prices (in the range of few hundreds Euros). Such system allows for listening any density and resolution music files (up to 384/32!), playing own CD's using a CD ROM drive, obtaining access to more than 10,000 web radio, many of which broadcast their transmissions with CD quality.
Great for a Second System As well without spending a bomb! Paired wit the Black Rhodium Music Link Mini-jack to stereo cable high fidelity within this price range is truly groundbreaking and pushes the definition of high end to a new level!
Black Rhodium Rhythm Music Link Cable (Silver Plated) - SOLD Separately.
HiFace DAC
Price : RM 880.00 with 1 Year Warranty.
Sales in Selangor and Klang Valley Only Through :
ACOUSTIQUE SYSTEMS, Amcorp Mall
Petaling Jaya (TEL : - 012-3393738 Contact Person : Mr.CN.Lim)
All Other Parts of Malaysia with No Dealers, Direct Sales
with FREE POS LAJU via : BEST TO PM on Hifi4sale.net
quintaruban- Dealer\Reseller\Trader\Service Provider
- Number of posts : 242
Registration date : 2011-02-20
Re: HiFace® "PocketDAC" by M2TECH 32 bit/384 Khz DAC (New - Made in Italy)
back in stock - bump!
» M2Tech HiFace ONE (USB to SPDIF Interface Made in Italy) NEW!
» M2TECH HiFaceEvo (Made in Italy USB to SPDIF Converter) New!
» M2TECH hiFace Evo + hiface Evo Supply
» M2tech Hiface Evo 24/192
» M2Tech hiFace Evo (USB 24/192 Interface for DAC) (NEW)
