M2Tech hiFace Evo (USB 24/192 Interface for DAC) (NEW)
M2Tech hiFace Evo (USB 24/192 Interface for DAC) (NEW) Empty M2Tech hiFace Evo (USB 24/192 Interface for DAC) (NEW)
Post by mikechai Mon Jun 14, 2010 5:38 am
M2Tech hiFace Evo
USB-to-SPDIF interface, based on the same technology as hiFace, but with many improvements. Hosted in a nice brushed aluminum case, with B-type female USB connector.
Main features:
- input for external supply (7 to 11VDC);
- input for external Master Clock (BNC with transformer);
- 2 x S/PDIF outputs (RCA and 75 Ohms BNC);
- AES/EBU output with XLR connector and settable format (consumer and professional) by an internal jumper;
- Toslink output
- ST output
- direct I2S output with 3.3V interface.
All outputs (except I2S) are transformer-decoupled to avoid ground noise and EMI interference. Three leds indicate power, data stream in input and external clock presence.
Specifications:
Size: 105x46x104mm (w x h x d, case)
105x50x142mm (w x h x d, total)
120x60x165mm (w x h x d, box) (to be confirmed)
Weight: tbd
Sampling frequencies (kHz): 44.1, 48, 88.2, 96, 176.4, 192
Resolution (bits): 16 to 32
Inputs: USB 2.0, supply, master clock
Outputs: S/PDIF x2 (RCA & BNC), AES/EBU (XLR), optical Toslink, optical ST, I2S (RJ-45).
Supply voltage: 7-11VDC
Supply current: 60mA (I2S not driven) (to be confirmed)
Master clock input voltage: 3.3V
I2S output voltage: LVCMOS (3.3V) with 25mA current capability on each line
Notes: hiFace Evo is compliant with S/PDIF and AES/EBU specifications for channel status bits. Sampling frequency and other information are encoded. hiFace automatically recognize the presence of a clock on the master clock input and switches to that signal whenever available. AES/EBU channel status settings can be chosen between consumer and professional by a jumper on the PCB. ST output is compliant with Avago application note AV02-0723EN[1].pdf for links up to 1.6km.
M2Tech hiFace Evo (USB 24/192 Interface for DAC) (NEW) Evo01
M2Tech hiFace Evo (USB 24/192 Interface for DAC) (NEW) Evo03
M2Tech hiFace Evo now opened for pre-order.
Mass production in August.
Order now to stand a chance to receive your unit in early July(while only a few units available).
Price: RM1200 per unit shipped.
Any questions, please email info@aegophile.net
mikechai
Number of posts : 17
Registration date : 2010-01-11
