M2TECH HiFace Evo (USB to Digital Interface)Sold
FEATURES
- Two quartz precision oscillators used on M2Tech HiFace, clock source for output data stream features a very low jitter. A more stable clock is recovered by DAC S/PDIF receiver; a low jitter produces a very limited sound image distortion and degradation.
- Phase noise (main responsible for jitter) is also very low: this guarantees a short and long range clock stability, also reinforced by a board supply voltage regulation (e.g. at environmental temperature stability is 2-5ppm approximately, compared to 50-100ppm performed by oscillators normally used on commercial CD players).
- Windows and Mac drivers are already available.
- Very high precision, very low phase noise (jitter) crystal oscillators are used.
- synchronous operation up to 192kHz is used in conjunction with proprietary drivers which allow for Kernel Streaming, Direct Sound and WASAPI operation.
- 100& made in Italy.
CONNECTION
- Size (W X H X D): 105x50x142mm
- Weight: 380g
- Sampling frequencies : 44.1, 48, 88.2, 96, 176.4, 192KHz
- Resolution : 16 to 32 Bits
- Inputs : USB 2.0, supply, master clock
- Outputs : S/PDIF x2 (RCA & BNC), AES/EBU (XLR), optical Toslink™, optical ST, I2S (RJ-45)
- Supply voltage : 7-11VDC (15VDC max.)
- Supply current : 140mA (idle, no output connected)
- Master clock input voltage : 3.3VPP
- I2S output voltage : LVCMOS (3.3V) with 25mA current capability on each line
Condition : 8.5/10, c/w original packaging Box & Walmart power adaptor.
Price : RMsold (COD at Puchong area ,Selangor)
Interested, Please contact me @ 016-2408080 (Alvin)
Last edited by alvin_choong on Mon Jun 22, 2015 6:44 am; edited 1 time in total (Reason for editing : Sold)
alvin_choong- Frequent Contributor
- Number of posts : 156
Registration date : 2009-05-23
» Sold-M2Tech HiFace 192khz digital audio interface
» M2Tech HiFace 24/192 USB/SPDIF Interface (USED)SOLD
» M2Tech hiFace Evo (USB 24/192 Interface for DAC) (NEW)
» M2TECH hiFace Evo + hiface Evo Supply
» M2Tech Hiface & Furutech Ag Coax RCA 1.5M (SOLD)
