Paradigm Monitor 7v3 Speaker (used)(SOLD)
Paradigm Monitor 7v3 Floorstanding Speakers
Specifications for the Monitor 7 v.3:
Design 2-driver, 2 1/2-way bass reflex,
Quasi-3rd order resistive port
Crossover 3rd order electro/acoustic at 2.0kHz
2nd-order electro/acoustic at 400 Hz
High-Frequency Driver 25mm (1") PTD
Bass/Midrange Driver 165mm (6 1/2") ICP cone,
die-cast chassis
Bass Driver 165mm (6 1/2") carbon- infused cone die-cast chassis
Low Frequency Extension 33Hz (DIN)
Frequency Response On Axis-0 degrees +/-2db from 47Hz-20kHz
Off Axis-30degrees +/-2db from 47Hz-18kH
Sensitivity Room/Anechoic 93dB/90dB
Suitable Amplifier Power Range 15-175 watts
Maximum Input Power 120 watts
Impedance Compatible with 8 ohms
Internal Volume 45 L/1.60 cu ft
Height, Width, Depth 101.6cm X 19.4cm X 39.1cm
40in X 7 5/8in X 15 3/8in
Weight 34.5 kg/76 lb per pair
Condition: 7/10
NOW Used Price : SOLD
Contact: SKY 03 77282686
At: Centre Circle Audio
8 Lorong Rahim Kajai 14, Taman Tun Dr Ismail
60000 KL
Last edited by centrecircleaudio on Wed Aug 22, 2012 3:40 pm; edited 2 times in total
centrecircleaudio- Dealer\Reseller\Trader\Service Provider
- Number of posts : 128
Registration date : 2009-03-19
» Paradigm Monitor Center 3 V7 Speaker SOLD
» Paradigm Atom Monitor bookshelf speaker (Used)(SOLD)
» Floorstand Speaker Paradigm Monitor 9 S7 Used
» Paradigm Monitor 7 S7 Floorstanding Speaker (Used)
