MS HD Power MS-s20v2 Power Extension (New)
~Fully complied to BS-1363 Sately Standards
~Integrated Power Noise Filtration Network using Selected Parts and Components
~Unique EmRF HUNTER™ Prevents Cross-Talk of EMI and RFI Between Applicance
~Excellent EMI and RFI Suppression to 60 db
~1µm Silver-925 Plated Socket Clips
~Heavy Duty Solid Copper Bus Bar System with Silver925 Plating
~Moulded-on Type Safety Plug Fitted with BS-1362 Silver Fuse
~1µm Silver-925 Plated Plug Pins
~1µm Silver-925 Plated Fixing Clamps for Fuse
~3 x 2.5mm² 6N OFC Double Screened Extension Cord
~Chassis Made of USA V-0 Grade Nonflammable Materials
~Sockets Pass the BS Standard 30,000 times plug IN / OUT test
~Full Life-Time Warranty (except fuse)
Specifications :-
Number of outlets : 6
Type of outlets : UK - conform to BS1363/A
Length of extension cord : 2 Meter conform to VDE standards
Inlet plug : UK - conform to BS1363; fused and unswitched
Fuse : 13A BS-1362 Silver Fuse fitted at plug;
13A BS-1362 Silver Fuse fitted at strip
Main Switch : Yes. Fitted at strip
Mains voltage : 200 - 240 VAC / 50Hz - 60Hz
Maximum current : 13 AMPS
Total wattage : 3,000 Watt (230V)
Dimensions : Chassis- 60mm x 402mm x 30mm (W x L x H)
Weight : 1.0kg
Selling Price : RM 820.00 (Call For Best Price)
________________
Best regard
Steve Chua
6012-6535703
603-77266893
CMY Audio & Visual Sdn. Bhd.
S336, 2nd Floor,
1 Utama Shopping Centre,
(New Wing) Bandar Utama,
47800 Petaling Jaya
» MS HD Power 78K Cryo Power Extension (Used) SOLD
» MS HD Power MS-s20v2 Power Extension SOLD
» Weiduka power extension/filter with thick M'sia power cord/plug.
» Power Extension Block (Used) SOLD
» UK to US power extension.
