How to get better sound from vinyl records?
Hi-Fi 4 Sale - Malaysia / Singapore Audio Forum & Marketplace | www.hifi4sale.net :: Audio & Video Equipment Marketplace :: Music & Video (CDs, DVDs, LPs, Blu-ray etc.)
Good day to all,
What can you do to get better sound from vinyl records? One way to achieve higher fidelity is to purchase more sophisticated equipment, such as upgrading a turntable, tonearm, cartridge, phono preamps or all of the above. Or, you can tweak your current system using some conventional. HEAR Records brings you 3 products from MUSIC HALL to accessorize and enhance any analog setup.
http://www.goldminemag.com/article/high-fidelity/how-to-get-better-sound-from-vinyl-records
1. MUSIC HALL Decoupling Cork Mat
A seemingly simple lightweight mat, the Music Hall Mat is made entire from cork and is designed to be a direct replacement for virtually any turntable mat. The secret to the Mat's great sound are the cork pads which suspend the record, a dozen small pads around the outside of the Mat and a single larger one for the spindle. These cork pads have excellent damping characteristics and do a great job protecting the record from the platter's vibration and allowing the vinyl to "speak" on its own. An additional advantage of the Music Hall Mat is its ability to "grip" the platter and the record simultaneously, eliminating the micro-slippage that plagues standard felt mats. This gives the Mat greater focus and improves pacing, especially on complex passages or those with substantial low-frequency content.
REVIEW : http://www.amazon.com/Music-Hall-MAT-Decoupling-Turntable/product-reviews/B004JO79RK
2. MILTY Zerostat Anti-static Gun (Stereophile Recommended Component)
This amazing little device known as the Milty Zerostat Antistatic Gun is an antistatic generator which has numerous applications, but our main use is to remove the satic charge on the surface of a record. Just squeeze the "trigger" of the Zerostat and a steady stream of ions is released. The magic comes from two powerful piezoelectric crystals and its patented compression trigger. The Zerostat will simply remove a static charge from the surface of an LP instantly. Perfect for use when the rotation of a Record Cleaning Machine and its suction tube build up a static field on the surface of your records. The Zerostat eliminates this static charge with the pull of the trigger. Highly recommended... in fact... this is an essential analog accessory!
REVIEW : http://www.amazon.com/MILTY-ZEROSTAT-ANTI-STATIC-GUN-BLUE/product-reviews/B0033SHDSS/ref=cm_cr_dp_see_all_btm?ie=UTF8&showViewpoints=1&sortBy=bySubmissionDateDescending
3. HUNT EDA Mark 6 Brush (Stereophile Recommended Component)
"Properly used (held with the bristles at a low angle against the approaching grooves and slowly slid off the record), these are the most effective dry record-cleaners avail-able. (JGH disagrees, feeling that they leave the dust on the record.) No substitute for an occasional wet wash." - Class D, 10/96, Page 141, review Volume 10 #8.
Please go to www.facebook.com/hearrecords to connect with us or come down to
HEAR RECORDS
#01-39 Burlington Square
Singapore
Please contact Nick +65 96460648 or email hearrecords2012@gmail.com for further queries. HEAR RECORDS is the local distributor for MUSIC HALL turntables & electronics. Thanks 4 reading.
HEAR RECORDS
Singapore
hearrecords- Dealer\Reseller\Trader\Service Provider
- Number of posts : 85
Registration date : 2013-02-02
» FS : Art Vinyl Play & Display Flip Frame
» Vinyl records
» Looking for Vinyl records...
» New and Used Vinyl Records
» Vinyl / Records
» Vinyl records
» Vinyl / Records
