DIY Hi-Fi chassis casing (New)
Note : All products come with packing for DIY. Own assembly.
Please contact : tangyauhoh@gmail.com or pm for stock availability/color.
Product code : ACH1, Fully Aluminium chasis/casing, flush finish. Suitable for tube amp or preamp.
Color : Silver/Black
Face plate dimension W435mm×H85mm×T7mm
Int Dimension : W400?D290?H75MM
Ext Dimension :W420?D310?H85MM
Description?The top and bottom Aluminium plate thickness is 3mm?Others all 7mm?Audiophile casing come
with flush finishing
Price : RM 320
Product code : PCH3, Thinking of diy Pass Aleph or Huge Class A power amp !
Mid tower
Power Amp chasis with heat sink.
Weight : 17 kg
Color : Gold/silver/Black
Ext Dim :W 480 X H180 X D480mm
Int ?W355?D470?H170MM
6 Heatsink ?180 X160 X 60mm each
Faceplate thick ness 7MM Alum plate
Face plate : Power supply on off button, 1 pair of Handle
Back panel ?IEC, Power ?Fuse?Speaker binding post 2 pair?RCA x 2.
Price : RM 550
PCH5 (Small Tower) Same as PCH 3 but slightly smaller (with the same accessaries )
EXT Dim : W480x H180 X D380
Price : RM 380
Product code : PCH 4
Model?Large Size Power Amp chasis with heat sink
Weight : 23 kg
Ext Dim :W 480 X H240 X D480mm
Int ?W355?D470?H230MM
6 Heatsink each 2kg?230 X160 X 60mm each
Back panel ?IEC Power ?Fuse?Speaker binding post 2 pair?RCA x 2.
RM 850
A-98
Face plate:480X80
External dimension:480X80X340
Internal dimension:415X340X73
Accessaries: Buttons, knob, RCA, fuse holder, IEC, Switch.
This model matches the Power amp chasis in terms of width
RM 140
Product code : PCH1
Power / Int amp Chasis : PCH1 INTEGRATED WITH EXTERNAL HEATSINKS
EXTERNAL DIMENSION : 430 x 400 x 150mm
INTERNAL DIMENSION : 360 x 380 x 140mm
FACEPLATE DIM : 435X150X7 ALUMINIUM
HEATSINK ?380 x 140 x 32mm
ACCESSARIES : On/Of switch, volume knob, source select, IEC, fuse, RCA,Speaker binding post,base stand.
Color : Silver
Condition : 10/10
Contact : tangyauhoh@gmail.com
Price : RM 320
Product code : PCH2
Power amp chasis : PCH2 INTEGRATED WITH EXTERNAL HEATSINKS
EXTERNAL DIMENSION:430X150X380MM
INTERNAL DIMENSION:390×380×140MM
ACCESSARIES : On/Of switch, IEC, fuse, RCA, speaker binding post, base stand.
Color : Silver
WEIGHT ?8.1Kg
Condition : 10/10
Price : RM 320
Product Code : IPC1
Power / Int amp Chasis : PCH3 INTEGRATED WITH EXTERNAL HEATSINK
FRONT PLATE : 6mm Aluminium. 430X110X6.5mm
INTERNAL DIMENSION:390 WX360 DX100 H
EXTERNAL DIMENSION : 430 W×380 D X 110H
ACCESSARIES : On/Of switch, volume knob, source select, IEC, fuse, RCA,speaker binding post, base stand.
Color : Silver
Condition : 10/10
Price : RM 260
INTEGRATED AMP : ICH1
FRONT PLATE : 6mm Aluminium. 430X102X6.
INTERNAL DIMENSION:400 WX330 DX100 H
ACCESSARIES : On/Of switch, volume knob, source select, IEC, fuse, RCA,base stand
Condition : 10/10
Price : RM 200
DAC : ICH2 - Finish stock
INTERNAL DIMENSION: 400 WX330 DX100 H
ACCESSARIES : On/Of switch, volume knob, IEC, fuse, RCA (4xinput+1xoutput) groups, Base standx4. Weight 4kg (exc. packing)
Color : Silver/Gold
Condition : 10/10
Price : RM 220
DAC/PRE : DCH1
Casing dimension : W 215mm×D 380mm/300mm×H 85mm
Function : On/Off/Volume control
Accesseries : Face plate 6MMAluminimun plate. IEC, volume control, volume knb, RCA, base standx4
Color : Silver/Gold/Blak - Limited color
Condition : 10/10
Price : RM 120
Price : RM 320
Mid tower
Weight : 17 kg
Price : RM 550
Price : RM 380
Weight : 23 kg
RM 850
A-98
Face plate:480X80
RM 140
Product code : PCH1
Color : Silver
Condition : 10/10
Price : RM 320
Product code : PCH2
Color : Silver
WEIGHT ?8.1Kg
Condition : 10/10
Price : RM 320
Product Code : IPC1
Color : Silver
Condition : 10/10
Price : RM 260
Condition : 10/10
Price : RM 200
Color : Silver/Gold
Condition : 10/10
Price : RM 220
DAC/PRE : DCH1
Condition : 10/10
Price : RM 120
kakibook- Dealer\Reseller\Trader\Service Provider
- Number of posts : 398
Registration date : 2009-07-19
» DIY Hi-Fi chassis casing (New)
» DIY HIFI Chassis Casing (New)
» DIY hifi chassis casing (New)
» DIY Hi-Fi equipment casing/chassis (New)
