845 Power amp + MC-7P pre amp (combo price ) grab it !!!
This beautiful amps available @ ANALOGAUDIOLABS
Call / msg +65 83195040
Brand New Dared VP-845 amp, sealed in original factory box
Now going VP845 power amp + MC-7P preamp @ combo price @ SGD 3300/- dont miss this chance to have a very good amp at the stock clear price.
DARED VP-845 , the BIG tube amp!
On the Dared product list, the VP-845 ranks second from the top down in the hierarchy and is branded Flagship Series, with the only other denizen there another 845 SET design that, justifiably enough, uses monoblock configurations. Apparently there's no question in the designer's mind that the 845 triode is superior to the much-adored 300B
Call / msg 83195040 now for an audition.
6moons reveiw
Visit our site for more info :
Call / msg / Whatsapp +65 83195040 now for an audition.
MC-7P
The tube covers (shielders) are coated with 18K gold (since all signal tubes are shielded, the preamp is very quiet -- one of the quietest MM phono preamps). Tube socket and PCB are planted with 18K gold too (no oxide issue here, best contact and connection). All signal wires are pure silver. The circuit design is very complex (Three tubes are used in power supply section in the circuit), Dared engineers and audiophiles worked together to collect best designs available and optimized this one with state-art technologies by computer programs. Here is, you simply cannot get better one with this price, period.
This excellent pre-amp is available at analogaudiolabs
Some reviews here: 6 Moons Review
Signal to noise ratio: 93 dB
Signal to noise ratio(MM): 75 dB
MM gain: 39 dB
Tubes: 12AX7 X 4 nos, 12AT7 X 1 no, 6P6P X 1 no, 5Z3P X 1 no
Size: 34 cm X 29 cm X 16 cm
Weight: 12 Kg
It uses 7 tubes and has two huge separate (yes separate--- only Dared design this way. Simply the best) power transformers: one for high DC volt and one for low volt of tube heaters and others. The capacitors use Audiophile grade and the key resistors use NOS AB and Vishay non-inductive. The tubes come with the amp are Chinese stock Ruby tubes.
6moons reveiw
MC-7P
MM gain: 39 dB
Weight: 12 Kg
analogaudiolabs- Dealer\Reseller\Trader\Service Provider
- Number of posts : 263
Re: 845 Power amp + MC-7P pre amp (combo price ) grab it !!!
» 845 Power amp + MC-7P pre amp (combo price ) grab it !!!
» Audio-GD NFB-17.2 & NFB-6 Combo (Price Reduced)
» M2TECH EvoDAC 32 bit 192 Khz Digital To Analog Converter (Combo) Last Day Before Price Change!
» Denon AVR-3808 AV amp: Should I grab it?
» WTB: Quad 34/606 pre/power amp combo
