KEF E305 5.1 Speakers with Floor Stand (Used)
KEF E305 5.1 Speakers with Floor Stand (Used) Empty KEF E305 5.1 Speakers with Floor Stand (Used)
Post by D_Y2k.9^ Mon Mar 16, 2015 2:40 pm
KEF E305 Black 5.1 Satellite Speakers + Subwoofer, RM4,500 nego
1 Year Old
Condition 8/10 (Speaker Stands have scratches on base)
COD @ KL/PJ
PM or whatsapp me @ 012-2509890
*Will upload images
Model E301/ E301c
DesignTwo-way bass reflex
Drive unitsUni-Q driver array:
HF: 19mm (0.75in.) vented aluminium dome
MF: 115mm (4.25in.) aluminium
Frequency range (-6dB)80Hz – 45kHz
Frequency response (±3dB)90Hz - 33kHz
Crossover frequency2.7kHz
Amplifier requirements10 - 100W
Sensitivity (2.83V/ 1m)86dB
Harmonic distortion
2nd & 3rd harmonics (90dB, 1m)
<1% 100Hz – 40kHz
Maximum output (SPL)109dB
Norminal impedance8Ω (min. 3.4 Ω)
Internal volume1.5Litres
Weight2.4kg (5.3 lbs.)
Dimensions
(H x W x D)
(with grille and base)
E301
E301c
260 x 136 x 159 mm (10.2 x 5.4 x 6.3 in.)
157 x 220 x 155 mm (6.2 x 8.7 x 6.1 in.)
Optional accessoriesFloor stands
ModelE-2
DesignPowered Subwoofer
LF Drive unit200mm (8in.)
Frequency range (-6dB)33Hz – 280Hz
Amplifier250W built-in Class-D
Maximum output (SPL)102dB
Low pass filter variableFixed 250Hz, 2nd-order
Low level signal inputsRCA phono socket
Enclosure typeSealed
Internal volume14.7Litres
Power requirements100 - 240VAC 50/60Hz
Power consumption250VA
Weight7.25kg (16lbs.)
Dimensions
(H x W x D)
320 x 430 x 270mm (12.6 x 16.9 x 10.6 in.)
D_Y2k.9^
Number of posts : 449
