Rogers PA-1A Phono Preamplifier
- TriangleART Turntable
- Von Schweikert Audio
- Endeavoraudio Audio
- KR Audio
- Graham Audio BBC LS5/9 BBC Licensed Monitor Loudspeaker
- Ensemble Audio
- First Sound Audio
- Rogers High Fidelity
Retail Price: USD$8000.00
Specification
- Frequency Response: +/- 0.1 dB deviation from the RIAA curve, 10 Hz to 20 kHz
- Gain: 50 dB- 65 dB selectable thru input tube selection, both 12AU7 and 12AX7 supplied
- Input Impedance: Moving Magnet- 47 K ohm, Moving Coil-transformer input with front panel selectable cartridge loading. 100 ohm – 1 Meg ohm, 100 pF- 500 pF
- Input Jacks- unbalanced RCA
- Output Impedance: 1 K ohm- 1 Meg ohm
- Output Jacks- unbalanced RCA
- Noise Floor: 0.1 microvolt, input referenced, A-weighted and un-shorted
- Signal to Noise Ratio: 90 dB at 20 mV input
- Channel Isolation: 75 dB minimum
- Tube Compliment: 2- 12AU7 or 12AX7 (user selectable,both supplied), 2- 12AX7, 2-6GH8
- Front Panel Controls: MC cartridge loading, MM or MC mode select, Mute switch
- Weight: 17 Lbs
- Dimensions: 18” width, 10” depth, 7” height
TKS FOR VIEWING…… CHEERS…..
Address: Block 925 Yishun Central 1 #02-229 Singapore.
Sunday & Monday 1200 HRS to 1700 HRS
Tuesday to Saturday 1200 HRS to 1800 HRS
Whatsapp / Line +65 98353600
- KR Audio
- Ensemble Audio
- First Sound Audio
Specification
- Weight: 17 Lbs
» Rogers PA-1A Phono Preamplifier
» BMC Phono MCCI MM/MC Phono Preamplifier (Used) SOLD
» Pro-Ject Phono Box E Phono Preamplifier (Sold)
» Phono Preamplifier
» NAD PP 2E MC/MM Phono Preamplifier
