Technics SU-Z55 Integrated Tuner ST-Z15 ( SOLD)
Technics SU-Z55 Intergrated Audio Amplifier
Power output: 40 watts per channel into 8Ω (stereo)Frequency response: 10Hz to 80kHz
Total harmonic distortion: 0.03%
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 75dB (MM), 86dB (line)
Output: 150mV (line)
Dimensions: 430 x 86 x 240mm
AM/FM Stereo-Tuner ST-Z15
- Type: Mono/Stereo Tuner
Tuning Bands: FM, MW
Tuning Scale: Analogue
FM Tuning Range: 88 to 108 MHz
MW Tuning Range: 531 to 1605 kHz
Sensitivity: 2.0uV (FM), 30uV (MW)
Signal to Noise Ratio: 65dB (FM)
Distortion: 0.3% (FM)
Selectivity: 60dB (FM), 27dB (MW)
Frequency response: 20Hz to 15kHz (FM)
Output: 300mV
Dimensions: 410 x 142 x 223mm
Let go as a set, working condition
Outlook 7/10
Price: 480
Call / WhatsApp 019-7304525
Check more goods at my garage fb @ck chupping
THE UNIT WILL BE PACKAGED VERY VERY CAREFULLY.
THE PLATTER WILL BE REMOVED AND NEATLY STORED UNDER THE UNIT ALONG WITH THE COUNTER WEIGHT.
YOU MUST PUT THE PLATTER AND COUNTER WEIGHT BACK ON THE UNIT, AND ADJUST IT ACCORDINGLY.
SELLING THIS BEAUTY UNIT "AS IS" WITH NO RETURNS.
KIND THANKS FOR LOOKING.
chupping- Frequent Contributor
- Number of posts : 274
Registration date : 2014-06-29
Technics SU-Z55 Integrated Audio Amplifier And AM/FM Stereo-Tuner ST-Z15
Good working normally
Condition: 7/10
Price: rm420 (price reduced)
WhatsApp / Call to deal 019-7304525
Check out more goods at fb @ck chupping
Condition: 7/10
Bump...price reduced rm cnc
Postage by buyer
Selling where as is...
Call / WhatsApp to deal 019-7304525
Postage by buyer
Technics SU-Z55 Integrated Audio Amplifier And AM/FM Stereo-Tuner ST-Z15 (Price revised)
Bump....for Amp & Tuner let go as set
Made in Japan
Supply 230V
NO remote
Postage by buyer
Selling as is...
Check out more goods at other ads & fb @ck chupping
Made in Japan
Supply 230V
NO remote
Postage by buyer
Selling as is...
» Technics ST-Z1 Tuner & Technics su-z2 integrated amp
» TUNER TECHNICS (SOLD)
» Technics tuner ( used ) sold
» Technics ST-S1 Tuner (Used)***SOLD***
» Technics ST-2400 Tuner(Used)(Sold)
