Adam Audio HM2 Bookshelf Speakers (Used)
The HM2 home monitor utilizes a 7” HexaCone® woofer with a large 39mm voice
coil and a big magnet. The mechanically rigid structure of its special
diaphragm or cone is responsible for the high precision and stability in
the bass and midrange.
Together with the A.R.T. tweeter, they deliver unsurpassed openness and
detail, revealing sonic information that is simply lost with
conventional technology.
- 2-way passive bass reflex speaker
- Woofer: 7" (177 mm) HexaCone®
- A.R.T. tweeter: see A.R.T. Technology
- Freq.response: (± 3 dB) 40 Hz - 35 kHz
- Efficiency: 87 dB/W/m
- Power handling: 100 / 150 W (sin/music)
- W x H x D: 220 x 370 x 320 mm
- Weight: 10 kg (22 lb.
- Finish: Black glossy
REVIEW :
Most sound engineers know Adam and audiophiles
know this name even better, because it simply denotes the excellence in
the highest-quality loudspeaker-manufacturing. Once you've owned a pair
of such speakers it's most likely to remain an Adam fan for the rest of
your life: the quality they put up is truly addictive!
Adam HM2 is the monitor-type of loudspeaker and if you make music or
process audio at home using a pair of these will add more precision to
your work while soothing the hearing. The new home series may look
diminutive, but the technology it packs is well worthy of the highest
ranking gear.
The Adam HM2 sports a 7-inch woofer built from Adam's proprietary
HexaCone material, which ensures vibration-error free oscillation and
supreme durability. The HM2 woofer is capable of reaching very low
frequencies, down to 40Hz, so the bass it will deliver will be quite
consistent. The enclosure is obviously made of wood and painted in a
very elegant glossy silver and is bass-ported, so the air flow will
travel better and produce warmer lows.
The strongest point in Adam HM2's design is the totally exquisite
tweeter: the ART (Accelerated Ribbon Technology) which elevates high
frequency sound-generating at new professional levels. While traditional
dome tweeters move air in a 1:1 ratio, the ribbon in the Adam speakers
reaches up to 4:1 air compression, which stands for more efficient
drivers and a richer overall sound, while the dimensions are sensibly
smaller.
Technically, air moves 4 times faster when pushed by the Adam's patented
ribbon while the overall size of the tweeter does not exceed the size
of a normal coil one. The active surface though, is significantly bigger
hence the improved performance.
Adam HM2 will rock your house with the most pristine sound and with a
simply embracing acoustic harmony: this hi-fi, audiophile-grade
loudspeaker will handle up to 100W (sinusoidal) and 150W (music) and the
frequency response is guaranteed to please the most demanding of ears.
Used for a year, in perfect working condition, original plastic wraps still intact. 2 scratches at the rear panel and a dent at a bottom corner as pictured in photos 3 and 5, caused by house mover, otherwise perfect.
Selling at RM2,900. Please contact 012-4937380 should you need further infos.
wflee- Dealer\Reseller\Trader\Service Provider
- Number of posts : 425
Registration date : 2009-03-12
Re: Adam Audio HM2 Bookshelf Speakers (Used)
Price reduced
Price reduced to rm2900.
» Adam Audio HM2 Bookshelf Speakers (Used)
» Adam Professional Audio - Compact Speakers (used)
» Adam Audio Pencil Mk3 Active floorstanding speakers (Cherry)
» Adam HM2 Bookshelf Speaker
» Adam HM2 Bookshelf Speaker。(Used。)~Sold.
