Naim Equipment Cables: 2 RCA to 5 Pin, 5 pin to 5 Pin, etc
Item: Chord Cobra VEE 3 interconnect 2 RCA to 5 Pin Din
Condition: 8.5/10. Item is in excellent condition
Price: RM550 or swap/topup
Some Info:
Cobra VEE 3 is a similar in construction and configuration to Crimson VEE 3, but with a crucial and performance improving difference. Cobra VEE 3 conductors are constructed from multi-stranded silver-plated oxygen free copper conductors and the conductors are insulated with FEP, a material with very similar performance characteristics to PTFE. This combination of materials is used extensively in Chord cable designs. We find that it improves signal transfer across a wide bandwidth, particularly noticeable at frequency extremes. The pseudo-balanced conductors are held in place with cotton spacers to reduce mechanical noise and protected with a dual layer high frequency effective foil and braid combination shield. The shielding is surrounded with a soft PVC to provide further mechanical damping and this is protected with a hard PVC outer jacket.
The Chord Cobra VEE 3 is fitted with Chord’s custom VEE 3 RCA plug. The ABS outer shell and the unique silver-plating process applied to the contact areas of the plug improve signal transfer across a wide frequency range. The signal return surround provides a secure high pressure contact with all types of RCA sockets. The centre pin is insulated with PTFE and the design of the plug and ABS outer shell provides good strain relief without compressing the cable and compromising performance.
The Cobra VEE RCA/DIN cable is terminated as standard with a 5 pin PREH DIN, the standard fitting for current Naim Audio equipment. We can also supply the Cobra VEE 3 with standard latching DINs and 4 pin DINs.
http://www.audiot.co.uk/products/chord-cobra-vee-3-interconnect-5188.aspx
Item: Naim 5-pin Din to 5-pin Din Cable
Condition: 8.5/10. Item in very good condition
Price: RM280
Some Info:
Price: RM280
» Naim equipment FS
» TeddyXPS (used) for Naim equipment
» Teddy Pardo XPS for Naim equipment (Sold)
» Tachii RCA to 5pin DIN cable for Naim equipment, REAN connectors
» Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors
